Sponsored by: CARiD
Wheel and tire not centered
Old Apr 18, 2018 | 04:24 PM
TA98LS1's Avatar
Default Wheel and tire not centered
The passenger front wheel on this trans am sits closer to the rear of the car. Whats wrong here and how is it corrected? Thanks
Old Apr 18, 2018 | 04:51 PM
BALLSS's Avatar
...did you hit something with the tire/wheel?
something in front suspension is not right. You are way closer to looking under the car than we are..
Old Apr 18, 2018 | 10:33 PM
Crf450r420's Avatar
Look at your lower control arm bushings and all others. Something is worn out completely or you have something bent.
Old Apr 19, 2018 | 06:33 AM
wssix99's Avatar
Save the manuals!
Are both sides the same?
Old Apr 19, 2018 | 08:31 AM
ZEN357's Avatar
I would say you have a bent control arm.
Old Apr 19, 2018 | 09:20 AM
TA98LS1's Avatar
I did hit something. And it broke the steering knuckle. I have replaced the knuckle and lower control arm. I checked today to see if something was up with the subframe and noticed this. The bracket that holds the swaybar to the frame is severely bent looks alot worse in person than the picture. Its bent toward the rear the same amount the wheel and tire is off. Is this the problem is the sway bar capable off pushing it back like that, thanks again
Old Apr 20, 2018 | 07:41 AM
wssix99's Avatar
Save the manuals!
Looks like you really need an insurance claim.
Old Apr 20, 2018 | 10:11 AM
biketopia's Avatar
My thoughts too, some damage was done if OP broke a knuckle. The cradle has probably been pushed backwards as well.
Old Apr 20, 2018 | 05:33 PM
BALLSS's Avatar
Frame shops can "pull" it back and you may need to replace some other suspension parts you have not already replaced.
Looks like a hard hit, curb jump kind of thing
If this is a insurance claim they would fix...although this kind of stuff can get to a "total" on cars this old if repair costs are high
I suspect the alignment is severely off
