Sponsored by: CARiD
Power Draw battery run down
Old Apr 21, 2018 | 03:02 PM
Steve Cox's Avatar
Question Power Draw battery run down
For the past year i have a power draw of around 1.8 amps measured at the main wire going into the under hood fuse block. Battery will run down in a couple days.
I have removed all of the fuses and relays on both underhood and the side dash blocks with no change in the draw.
Any ideas on where next to look?
Old Apr 21, 2018 | 07:19 PM
Steve Cox's Avatar
FYI: she is a 02 TA vert
Old Apr 21, 2018 | 09:47 PM
Crf450r420's Avatar
remove alternator main lead and see if the draw goes away. Sounds like you may have failed diode in the rectifier bridge.
Old Apr 22, 2018 | 08:15 AM
B52bombardier1's Avatar
+1 on removing the alternator connection. As suggested, a diode has perhaps failed towards ground. I'll bet you lunch that a good Fluke voltmeter at the battery set to measure AC volts would show some AC leakage reaching the battery with your car running. Rev up the RPM a little and watch the multimeter. This should be less than around .05 AC volts at the battery with the motor running. AC volts hitting a DC-loving 12 volt battery is never good for the battery.
Be advised that a cheap multimeter will struggle to measure small amounts of AC. Think cheap Harbor Freight, Home Depot or Lowes - they probably won't be good enough here. You will need to spend 30-ish or more dollars on a multimeter but nothing like what I spent on my Fluke 17B model.
Rick
Old Apr 22, 2018 | 09:46 PM
Steve Cox's Avatar
Quick update, alternator checked ok. Traced it to the Monsoon AMP.
Old Apr 23, 2018 | 12:41 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
This is interesting...
...how was the stock amp still getting power with every fuse and relay pulled?
Old Apr 23, 2018 | 01:14 PM
Steve Cox's Avatar
Found the stock amp uses a fusible link, then to fuse 24 IP block.
Must have missed the drop when i pulled it the 1st time
Old Apr 25, 2018 | 09:33 AM
biketopia's Avatar
Good catch. And thanks for posting back what you found, with detail even!!
Old Apr 25, 2018 | 12:15 PM
WhiteBird00's Avatar
Ungrounded Moderator
That would be fuse #4 (not #24)... 25A fuse labeled RADIO ACCY. It provides battery (constant) power to the Monsoon amp, power antenna and remote CD changer in vehicles that have them. The amp uses signal sensing to turn on and off unlike most aftermarket amps which have a separate control signal. So your amp is "seeing" an audio signal somehow that's keeping it turned on or it's defective.
