Sponsored by: CARiD
AC not producing ice cold ac?
Old May 30, 2018 | 04:26 PM
Mike1711's Avatar
Default AC not producing ice cold ac?
Hi I currently have a 98 Pontiac firebird. I had got my ac fixed recently. There was hose that was leaking Freon and due to that it was not producing cold air. The ac is fixed but the issue is that it is not ICE COLD ac. It is cool air but not cool enough. When you turn on the ac after it is left outside in TX hot weather for about an hour the ac is cool in max setting but you still feel that it is not cold enough and still feel that it is still hot. I need to get some advice and see what might be the issue before I take it to the shop again. Also for a few seconds yesterday it started to blow warm air and then went back to the cool air. Can somebody please give some advice. Thank you
Old May 30, 2018 | 05:04 PM
SoFla01SSLookinstok's Avatar
Hey man. From what I've read I would say the system may not be charged with the correct amount of refrigerant. Could also be a problem with the compressor or something else. The way it blew warm for a few seconds then back to cool sounds like a switch cut off the compressor. Tell whoever is working on it all the details.
Old May 30, 2018 | 08:24 PM
B52bombardier1's Avatar
Get a set of AC pressure gauges and tell us what they say. Low side too low - system need FREON? High side too high??
Rick
Old May 30, 2018 | 09:58 PM
RockinWs6's Avatar
Your system doesn't use "FREON" it uses refrigerant 134A. Don't try to put "FREON" in it trust me.
Old May 31, 2018 | 06:20 AM
drdave88's Avatar
Get an IR temp gun or some way of accurately reading the temp coming out of the vents. When I worked in a dealership this was a common occurrence. A customer would come in on a very hot day and would feel their air was not cold enough, yet when taking a reading at the vent, it was around 40 degrees.
I also agree with having a set of gauges hooked up to verify correct pressures.
Old May 31, 2018 | 02:16 PM
Mike1711's Avatar
Thank you for your reply. The car repair checked thru and had determine that this hose they ordered from the dealership was the issue because it clearly showed it was leaking out Freon out of the hoses. I need to make sure which type of Freon or refrigerant hey had used.
Old May 31, 2018 | 02:18 PM
Mike1711's Avatar
Rick
thank you for your reply. I have never hooked up the ac pressure gauges. I never really tried and I really don’t know how to do it. I will have to take it to the car repair place to see what is going on.
Old May 31, 2018 | 02:20 PM
Mike1711's Avatar
thanks for your reply. This may be a silly question. What’s the difference between Freon and the refrigerant 134A? Do you think they have not put enough in the system to produce ice cold Ac? I hope it’s not something else because I clearly check with the car repair place before getting the repair done and they clearly told me that the hose clearly is leaking Freon out when they did the dye check.
Old May 31, 2018 | 02:23 PM
Mike1711's Avatar
thanks for your reply. When taking the reading showing 40 degrees why was it still not cold? Was there an issue in the temperature control showing incorrect temperature when hooking up the gauges? I’m not sure on how to hook up the gauges. I will check with the car place because they did this work.
Old May 31, 2018 | 03:00 PM
As what drdave88 stated. I also worked in a dealership & remember things like that as well. Your A/C system will not always produce the exact same air temp out of the vents. If on recirc, or full outside air, different temps. outside. Your air will be colder on a 75 degree day than a 95 degree day. Or colder at night than during the day. You can buy little thermometers to set in one of your vents. Have someone look over the system & pressures. Good luck.
Old May 31, 2018 | 03:41 PM
WhiteBird00's Avatar
Ungrounded Moderator
Freon is a brand name for R-12 refrigerant that has come into common use like Kleenex has become a term for facial tissues. Lots of people still refer to A/C refrigerant as Freon even though it really isn't. R-12 refrigerant is a CFC product that was banned because it contributes to ozone depletion in the atmosphere and it became unavailable in '93 unless you had a special permit to buy it. R-12 was replaced with R-134a in all cars produced for the '94 model year and newer. Nobody makes R-12 anymore but there is still a supply that comes from recycling by permitted repair shops. Your repair shop probably has a permit to buy R-12 for repairing older car A/C systems but no reputable shop would ever use it in a newer vehicle.
Old Jun 3, 2018 | 08:12 AM
LS1121's Avatar
Would it be possible to run 22 in our systems? Just a thought.
Old Jun 3, 2018 | 08:47 AM
RockinWs6's Avatar
WHY would you want to? There is absolutely NOTHING wrong with R134a EXCEPT people don't understand how to use it properly. I always hear the same bs "MY AC ISN"T COLD ENOUGH" and its blamed on the 134a. Every time its because its either overfilled or under filled or some type of mechanical problem in the system.
Example NEW Ford truck f350 guy complained it got cool but never got cold. The Ford dealer actually told him it was normal..........................I checked it and it was low on refrigerant! It was never filled properly from the factory. Few ozs later it was so cold you freeze yer hiener off in dat truck.
R134a systems need proper filling, too much or too little and they don't get cold enough. R12<freon systems were much more forgiving when it came to refrigerant volume.
Old Jun 3, 2018 | 02:10 PM
LS1121's Avatar
WHY would you want to? .
because I have a **** Load of it and it is FREE!, that's why.
Old Jun 4, 2018 | 04:54 AM
RockinWs6's Avatar
R134a is cheap, less than 5 bucks for 12 ozs.......................can't get cheaper than that.
Old Jun 4, 2018 | 08:16 AM
R-22 is a high pressure refrigerant while R-134a is a low pressure refrigerant. Charging an R-134a system with R-22 would result in problems such as an overheating compressor.
Old Jun 4, 2018 | 05:16 PM
LS1121's Avatar
OK Thank You, a reasonable answer from you is what I always get.
Old Jun 5, 2018 | 12:39 PM
Mike1711's Avatar
Hi this is a very nice answer. On my firebird it is the same issue. It’s cool but not ice cold. So you’re saying that it is overfilled or underfilled refrigerant? I’m not sure if they used refrigerant or Freon. Which would you recommend for a 1998 Pontiac firebird so I can take it back to them to get them checked because I live in Texas and once the car is out in the sun for an hour it is cool but not cold enough and you still feel hot even though the ac is on. Also I had feel warm air for a few seconds and then it went back to cool. Any idea about that? Can you please let me know. Thank you
Old Jun 5, 2018 | 12:46 PM
In any North American vehicle manufactured since 1994, you don't have a choice... you must use R-134a unless you find someone to provide and install bootleg R-12 (i.e. illegally). You may or may not have the correct amount of refrigerant in your system and that may be causing your symptoms but you almost certainly don't have R-12 (Freon) in there.
Old Jun 5, 2018 | 01:06 PM
Mike1711's Avatar
Hi so I should just tell them to check the refrigerant level? It is cool but not ice cold. Thank you for your help
