Camaro mpg question
20 MPG isn't that bad considering your car is 20 years old now and it probably wasn't tuned after the cats were removed. In optimal form you could probably get a little better.
On 8 trips to Florida from Ohio running with the traffic in cruise control on interstates,mpg was 24.5 ( verified by a ScanGaugeII hooked to the OBDII port). Speeds were typically 75 in a 70 and 70 in a 65. MPG is 'right foot dependent' so city driving is disregarded. An occasional full throttle will really drop mpg down. Overdrive ratios are different for M6 and A4. M6 is .5 and A4 is .7. Dropping mph down on freeway cruising to 60 gives me 25.5 mpg on the ScanGaugeII.
If I am Realllllllly nice I can get 27 but most of the time I get 25-26 on the highway. However I'm pushing a little over 400 hp. Big price difference between Now and Then.
When the car was designed, we had a 55 mph National speed limit on the highways!
My best mileage was on a long 100% highway run after a tune up and carbon cleaning. I got 29 mpg. During full City driving, I get 12 mpg. So, there is quite a range.
To baseline really where you are, I would suggest taking a long run on the highway at 55 mph and seeing what you get.
These numbers might be achievable with a well tuned car, and as you point out, on an all-highway tank. The minute one goes off-highway, even for a little bit, the numbers become grossly diluted. An all-highway run at a constant speed is really the only reliable way to benchmark something like this, which I don't believe the OP has done yet.
