Sponsored by: CARiD
Rusting light sockets
Old Aug 4, 2018 | 01:55 PM
TA_Freak's Avatar
Default Rusting light sockets
So as we all know our front parking / turn signal lamp lenses leak - and with the nature of the socket being vertical, water get's in and kills the lamp and eventually the socket. I've replaced several in the life of this car.
Today I blew out all of the moisture, replaced the lamps and sealed it with silicone .
Has anyone ever tried that? Im curious to see how long these lamps will last like this.
Old Aug 5, 2018 | 08:47 AM
wssix99's Avatar
Save the manuals!
It's more the fact, I think, that the lenses are set in the bumper which takes a beating from road debris. I've lost a few, but they have all cracked; from stones, birds, squirrels, etc.
Some members have seen general quality issues with the aftermarket replacements. If you are going to keep the car a while, you may ****** up some OEM lenses, while we still can.
Old Aug 5, 2018 | 05:06 PM
TA_Freak's Avatar
My originals are still hanging in there. For me I've seen that they have hair-line crack(s) and can allow water in that way. I am thinking of spraying a clear coat on them and stop the leak at the source. I put the sealant around the lamp/socket - so we'll see how that does.
Old Aug 5, 2018 | 05:17 PM
AINT SKEERED's Avatar
When I changed a bulb a few months back , my sockets were rusted. My lenses are in great shape and car has always been garage kept ,driven in rain maybe 4 times in its life with 46,470 miles on car.
Old Aug 5, 2018 | 08:06 PM
TA_Freak's Avatar
Fortunately the rotten sockets can be had new at the parts store for around 10 bucks. I've changed them out a few times. It also allowed me to extend the wiring out so that I can pull them completely out from the front and not have to deal with the lamp swap from the hatch below.
Old Aug 5, 2018 | 09:48 PM
good to know. Thanks
Old Aug 6, 2018 | 06:52 AM
wssix99's Avatar
Save the manuals!
The hairline cracks on the face are structural and sprays/clearcoats will just crack through. Tapes work but look like junk. At the point the face of the lens is cracked, then they need to be replaced.
Are you talking about leaks where the socket screws into the back of the lens? There is a rubber grommet back there to make the seal. New grommets can be had for a few cents. If those have gotten bad and rotten, why not just replace them with a new rubber seal?
Old Aug 7, 2018 | 01:15 PM
TA_Freak's Avatar
I always replace the rubber gasket when I change out the socket. There is still moisture that rusts out the socket from somewhere. If the lamb was inserted horizontally at the back, that problem would most likely not exist.
Old Aug 7, 2018 | 01:28 PM
BALLSS's Avatar
dialectic grease in the socket after you clean or replace it.
Old Aug 8, 2018 | 07:32 AM
wssix99's Avatar
Save the manuals!
That's the problem to figure out. I'd think that if you took the lens out and did some testing in a sink, you could find it.
I recall that some other T/A owners have had issues with the backs of the lenses cracking from heat, etc. Maybe that's happened here? I'd normally suggest to switch to a Formula bumper (including the Formula lenses), but I suppose that's not practical for you.
Old Aug 8, 2018 | 10:20 AM
Need4Camaro's Avatar
Its the socket, not the lense seal. I did a test (note you can only do this with LED Bulbs as they do not get hot.) I taped some plastic shielding over the bulb and socket area so the entire socket is covered by plastic... Run through heavy rain, not a drip got into my lenses... Take the plastic out and I will have puddles of water accumulated in the lense. This is even with new sockets and rubber grommets.
Old Aug 8, 2018 | 03:40 PM
LS6427's Avatar
When one of my sockets rotted from water I purchased real glass lenses off ebay. Then bought the new pigtails for each and spliced them onto the factory wires. Once the bulb was twisted in it was 100% sealed. But I also sealed around the socket base with silicone. Been on there now for like 15 years. Not sure if the silicone is still there, but no way water can get into these glass lenses. I've got the dual colored LED's in them with the flashers.
Old Aug 9, 2018 | 06:59 AM
wssix99's Avatar
Save the manuals!
The factory sockets and lenses don't do this when the car is new. So my first pondering would be if this is due to bad seals in aftermarket sockets? (We've seen this in other aftermarket equipment with bad/improperly sized wire seals.)
The socket has the larger grommet, which seals the socket body to the lens housing and then individual wire seals, which seal the wires to the socket body cavities. All are replaceable, although the wire seals would probably require a special crimper and new terminals (they are crimped to the terminal, also) or a proper Delphi socket would need to be installed.
Old Aug 9, 2018 | 09:43 AM
I would say much more likely to occur with aftermarket housings but my factory housings on my 97 RS did this too. Sometimes I wonder if its because over time the heat from the bulb in some way warps the assembly, they get pretty hot in that confined space - the same thing lead to cracking of the lenses on my Firebird which I was forced to use LED bulbs to resolve.
Old Aug 11, 2018 | 05:07 PM
wssix99's Avatar
Save the manuals!
The heat would probably dry up and crack not only the grommet but the wire seals in the lamp cavity.
