Sponsored by: CARiD
Need some help please
Old Aug 7, 2018 | 07:51 AM
zootzee's Avatar
Default Need some help please
Hey guys I'm hoping someone can help. I have a 97 Trans Am with only 60,000kms on it.
Wen I was driving home Friday afternoon after an hour drive it seemed to shift kind of weird between 1st and 2nd. I got home check the fluid and all was good. This was around 6 when I got home.
I tried to start it to go out later around midnight and all it does is crank over won't start.
I went to start the car the next afternoon and it started.
It didn't start right away the engine turns over a bit i much before it starts. I notice this in the past week almost like a carburetor car would. I thought this to be out of the Norm.
I put a clear spark plug tester on it and I have spark. After about 3-4 starts it won't start again.
Later my buddy came over and we heard the fuel pump kick on the car started and ran nice. Great spark from the spark plug tester.
Shut it off and started it again no problem.
The fourth time wouldn't start again and the light in the spark plug tester wasn't very strong.
I was guessing the ignition control module. But I went to AutoZone and they tested it (5 times) and said it was good..
So far I believe it's getting gas and enough the battery is good and the ICM tested good.
Any thoughts?
Old Aug 7, 2018 | 09:30 PM
LS6427's Avatar
That exact issue in the LS1 is almost always a failing Crank Shaft Position Sensor......
I don't know much about the LT1....but if you have one, check it out.
Old Aug 9, 2018 | 08:50 PM
zootzee's Avatar
Thanks I'll take a look. I'm at a loss so I'll try everything
Old Aug 9, 2018 | 08:51 PM
zootzee's Avatar
Appreciate it
Old Aug 9, 2018 | 08:55 PM
zootzee's Avatar
I forgot to add this
I took the ICM to get tested. Now that I've put that back in and together it just turns over and won't start at all. It still turns over took the ICM to get tested. Now that I've put that back in and together it just turns over and won't start at all. It still turns over like it wants to start the first time then nothing.
Old Aug 9, 2018 | 09:47 PM
LS6427's Avatar
Whats the ICM....?
You mean the PCM...?
Old Aug 9, 2018 | 09:49 PM
LS6427's Avatar
I would go buy a new Crank Shaft Position sensor......drop the starter and there it is. Swap it out. Put the starter back.
If it doesn't work....clean it off and get a full refund. Just tell them it wouldn't fit because someone modified your sensor port. They have no clue......
That sensor could just be totally failed now.
Old Aug 9, 2018 | 10:28 PM
Felipe A Morales's Avatar
Default Car dies when i run my AC for a while
I have a 02 camaro z28 all stock besides a cutout. My question was that when ever i run my AC for a while like 30mins to an hour my car starts losing rpm and dies. When i try to start it back up it cranks but wont start i have to wait like 30 mins for it to start back up. Any ideas what it could be ?
Old Aug 10, 2018 | 09:35 AM
zootzee's Avatar
Originally Posted by LS6427
Whats the ICM....?
The ICM = ignition control module
Old Aug 10, 2018 | 11:05 AM
zootzee's Avatar
I think that is it
Old Aug 11, 2018 | 06:13 PM
yourhuckleberry's Avatar
Did you figure this out?
Old Aug 11, 2018 | 08:47 PM
zootzee's Avatar
Still working on it. Going change the crank position sensor when I get in town Monday night. I'll update Tuesday morning
Old Aug 12, 2018 | 01:49 AM
LS6427's Avatar
Originally Posted by zootzee
I think that is it
Bingo....easy fix. 15 minutes. But you gotta get the front end up in the air.
Old Aug 12, 2018 | 09:14 AM
zootzee's Avatar
Do I need to remove the starter and the exhaust to get to it? I'm hoping to be home tonight to tackle this just want to be prepared.
Thanks
Old Aug 13, 2018 | 12:35 PM
zootzee's Avatar
Well I changed the crank sensor. Which is in the front of the motor not under the starter.
Changed the fuel filter fuel comes out nice.
Still turns over won't fire.
I had it running for a bit. Shut it off and wouldn't start again just turning over.
Old Aug 13, 2018 | 01:02 PM
zootzee's Avatar
Just changed the ignition control module too still nothing.
Put the code reader in and no codes
Old Aug 13, 2018 | 01:14 PM
8.Lug's Avatar
Isn’t that an LT1 car? You should ask in the LT1 sub forum, that motor is completely different from the LS. Not even remotely the same.
Old Aug 13, 2018 | 03:01 PM
bammax's Avatar
Fuel pump on the way out or opti dying. Both can cause the same symptoms. Both suck to fix. You have to measure fuel pressure at the rail at a time when the car won't start to see if the pump is weak during a no start condition.
Old Aug 15, 2018 | 05:39 PM
LS6427's Avatar
That code is Crank Shaft Position sensor......they are the same in what they do for both the LT1 and LS1......
You could have bad (NEW) sensor....its happen ed dozens of times. But you'll need to check the rest of those items associated with the CSP sensor code.
As far as Opti-Spark.....I have no experience with that.
Old Aug 15, 2018 | 06:26 PM
zootzee's Avatar
Thanks I'm thinking fuel pump
Replaced
PCS
ICM
Fuel filter
Fuel relay
And I have spark just won't stay running and my fuel pressure drops
