Half of my Header bolt holes are stripped!! HELP!
When installing my headers onto my new to me heads on my ls1 3 of the bolts spin, 2 are cross threaded and 1 won't even catch thread. How do I fix this?? I don't want to take out the heads I just finished putting on... Can I either tap (without drilling) a bigger sized bolt? If so what is the next size up from a 8MM x 1.25 bolt? Or I've heard if you bend strands of copper wire in the hole it'll help catch the threads. I really don't want to take the heads back off. Please help.
I would rather spend 5 bucks on a few m10x1.50 bolts then 70 on a timesert kit. I just want to know if it's be ok to drill out the holes and tap with that size tap? New threads and a new bolt will work, no?
I wasn't the one to put the headers back on. I mentioned that before. All I want to know is if it's ok to tap a m10 tap in
plus to my knowledge they were already cross threaded
<br /><br />Might want to figure out what else has been wrenched on then. I know you want an easy answer to a bugger of a problem but there really isnt one. Heads come off easy, and fast, gaskets if MLS can be reused and some say bolts too. I replace both for low cost and fast Summit ship. All I can say is if it were my car? I'd peel the heads both off, check valves and seats, replace seals and springs and go from there but thats how I do things. I was young and impatient once too and spent at least one full night out in the middle of the bush freezing my nads off trying to get my sled back together after I tried the quick repair route. Sooner or later we all learn quick cheap repairs usually aint good and good repairs usually aint quick, or cheap.<br />
Maybe a thread chaser, but not a tap but OP if you try a thread chaser be sure to get a good quality one ARP etc. Chasing threads especially when crossed is a tad tricky
