rockauto sucks
In this particular case, the core is thicker. Are the tanks the same or are they also different? If the latter, then the geometry would be off, making it possible that the connector might be crossthreaded, leading to a leak. Not saying that this is the case, but looking at it from the supplier's point of view.
I put Teflon tape on the fitting to stop the drip but who knows how long that will last. The work took forever to do, and they won't Warranty this New Radiator. Terrible policies.
Any Ideas on how to fix this would be great.
- Like other retailers of branded products, RockAuto does not offer any product warranty of our own--we honor the warranty provided by the manufacturer of the product. If you have a problem with a part during the warranty period, please submit a warranty claim through our Order Status & Returns page.
To fix the issue maybe you should try contacting the manufacturer of the radiator and explain the details.
Unfortunately, a lot of time in the US companies will tell a customer "NO" When the company knows it's in error. Often this gets rid of a lot of legitimate claims because the customer gets flustered and gives up. Being calm, cool, polite, consistent and persistent often pays off. Getting upset or belligerent never pays off.
Get all of your facts, order numbers, pictures of the issue, story organized and be ready to provide objective evidence of why your claim should be covered.
This normally gets me an acceptable result.
It doesn't necessarily get exactly what one wants because compromise can be needed on both sides.
When I bought my Bosch starter, they argued up and down that they wouldn't return it because I had tried to install it. It didn't work because the gear was making too little contact with the flywheel teeth, causing a screeching sound. I then purchased similar starter from Summit, and that did the same thing. Both part numbers were confirmed by many others to work on the ls1 in 98-02 F-body cars. I then bought a powermaster starter and that worked just fine without shims. I eventually got rockauto to process the return but they made the entire process very lengthy, much more so than Summit. If they had any sense of customer service, they would have behaved like Summit did.
Yes, it's still possible that the customer damaged it and wants a free replacement but there are better ways to handle that situation as well... tell the customer that the replacement will be shipped when the returned part is inspected for damage or, if the delay would be a big problem, have the customer agree to pay for the replacement and get a refund on the returned part after inspection.
I agree - Rock Auto sucks. I will be using them MUCH less in the future. :Z
