Small rain leak pass window
https://ls1tech.com/forums/general-m...-included.html
https://ls1tech.com/forums/general-m...dow-guide.html
If you can see through the gap, you most likely have a door geometry issue with the glass mechanism in the door. If the space is paper-thin, then it could be to the embrittlement of the weatherstripping. (You should still check for the regulator issue, above. If you ever had the window regulator removed and replaced with bolts (instead of the proper rivets), that will eat into the door skin and will start causing problems like the one you are describing.
If you have a properly installed regulator, then you can simply adjust the glass to seal more tightly against your weatherstripping. Just follow the shbox window adjustment instructions, exactly. (If you don't follow them in his exact order and with precision, the glass will get out of whack and further out of sorts.)
https://ls1tech.com/forums/general-m...-drowning.html
You're likely dealing with a body seam or weatherstripping issue in the hatch channel.
You may need to get new weatherstripping if messing around with your T-tops to get a better adjustment and flush fitting doesn't solve your problem. Also, you don't need to resort to clear gorilla tape. Man, I am self conscious as is about my gorilla tape work to get my aftermarket LS1 Trans AM style hood to work with my LS1 Camaro air box on my LT1 Trans AM. Hopefully this summer I can find a shop to fiberglass in a permanent rain baffle and make the hood legit. Trust me, you don't want to drive around with any kind of duct tape to solve a car's problem, believe me! This weatherstripping issue is something stupid, either the T-tops are not flushed up or crushing a drainage duct, or you need to replace the weatherstripping like I did.
https://ls1tech.com/forums/general-m...ml#post9907149
https://ls1tech.com/forums/general-m...ml#post9909346
https://ls1tech.com/forums/general-m...l#post13300693
If that information is not enough, you might be able to find further discussion and description by searching for the TSB numbers mentioned in the links above.
