HELP! 3 gauges acting crazy.
https://youtu.be/Fxwev-CMGfs
On a side note, there are many videos and articles about grounding the crap out of everything...I've gone as far as to put extra grounds in many of my cars.. block to fender well, block to battery, manifold to fender well, manifold to block. The delicate electronics are driven by voltage differences which are impacted by resistance (bad connections). If you have any bad or intermittent connections, stuff won't work correctly.
It is true that bad grounds can cause many problems. But I avoid that expression because it often leads to people adding additional unnecessary grounds to circuits instead of tracking down the real source of a problem. Check the ground as part of the diagnostic procedure but if it's good then move on to something else. Adding more grounds isn't going to solve anything.
. To strengthen the "ground argument", grounds are among the few exposed connections in late model cars. A small resistance behind a reference ground is a game changer. With operating ranges of a few volts (especially sensors) where tenths of a volt matter a bunch, good clean reference grounds are critical. As far as older cars, how many of us have seen old Nova's and Camaro's with screwed up brake/tail lights? Guess what that problem is?
When repairing a ground, I put one or two drops of LPS1 on the connection to avoid future corrosion.
On another related and possibly controversial topic, I hate the solder that is now in use on most electronics (solder with lead is pretty much illegal). If you find some old stuff at a garage sale, buy it. The new stuff literally has an expiration and re-soldering connections on newer electrical components can bring broken components back to life.
