Camaro 1995 no start clicks
Got a 1995 Camaro z28 been working on the last year or so has developed a strange intermittent no start issue that now has become permanent, essentially first time it left me stranded had turn key gauges would die no click no start, came back to life a day later? After that getting intermittent turn key click no start and now it just clicks, redid the positive terminal at the battery getting good voltage there check grounds on block near starter and up top all made the test light illuminate, also tried using theft relay ran wire from yellow to purple solenoid wire tried to start still just clicks, banged on starter and solenoid no success as well, one thing interesting, when I go to start it no light dim inside but the headlights out front die, is it normal for these headlights to go off when you try and crank it? Is there any place I can tap into the purple wire to bypass the ignition switch? I am just trying to figure out if this is the ignition switch, a hidden ground or the starter itself , any help greatly appreciated before I swap the starter
Really?! Spend that money when he has a bad starter? Dude!
mmikeman, I probably went through three re-manufactured starters from NAPA until I finally found a good one, getting fed up and trying Advance Auto. When they went bad they were clicking and furthermore the gear had to have been overextending because two out of the three had broken housings!
Sure it's not just a dead battery? If you have a bad cell it'll be intermittently bad with temp and power spikes causing it to act up until eventually starting will be more than the remaining cells can handle.
All good points but he posted this up on the 10th and I'm betting he's already figured it out but has failed in not letting us know! Or is it because he feels shamed for asking the question in the first place. Google it!
An old timers trick, get under the vehicle with a hammer, and have someone else try to start the vehicle, while the starter is clicking start striking the starter with the hammer, if it then turns over, you have a bad Bendix and need to replace the starter.
