Sponsored by: CARiD
weight of lifting front - edit: added pic
Old Nov 10, 2019 | 08:51 PM
patSS/00's Avatar
Default weight of lifting front - edit: added pic
Anyone know what the weight of the front of an fbody is when lifting with a hoist (cherry picker), no engine or kmember, rear on the ground? More than 500 lbs?
Old Nov 12, 2019 | 08:21 AM
drdave88's Avatar
If you're worried about the cherry picker not being able to, I wouldn't be concerned. Lots of us have done it without issue. I had the arm completely extended on mine when I did it (more than once) and no issue.
Old Nov 13, 2019 | 07:14 PM
patSS/00's Avatar
Related question: is this an OK place for attaching the lift chains? I couldn't find anything better without taking off the whole front. Haven't actually lifted it yet.
Old Nov 14, 2019 | 08:32 AM
drdave88's Avatar
I would not lift on that part, it's likely going to bend easily. Most will go around the upper radiator support, use a strap, not a chain to minimize damage to it.
If you do a search on "how to remove the engine from the bottom", there are many threads on how to do it properly, with pics.
Old Nov 14, 2019 | 08:48 AM
patSS/00's Avatar
Yeah have looked at lots of threads but no one shows where they attached the chain. Upper rad support looks even more flimsy to me, that's where I was going to use originally, decided against it. Lower support at least has a vertical brace in the middle. Strap doesn't allow adjustment of length, I also tried that.
Old Nov 14, 2019 | 09:00 AM
jlangley's Avatar
I would place a 2x6 or two under that to spread the load a bit and protect the rad support from the chains.
Old Nov 14, 2019 | 09:06 AM
patSS/00's Avatar
Good idea, thanks. Just happen to have some 2X6 pieces I got for making a base for jack stands when the car is pointing up.
Old Nov 14, 2019 | 09:31 AM
drdave88's Avatar
Having a problem posting pics from some of the parts cars I've stripped down. One shows a good shot of where I put the strap. I'll see if I can get it posted.
Old Nov 14, 2019 | 09:40 AM
drdave88's Avatar
Got one of the images to upload.
Old Nov 15, 2019 | 11:04 PM
eb110americana's Avatar
I put a hook at the end of the chain and hooked it under the hood latch point. The front end is so light at this point without engine/trans and subframe, this is fine. It has to be strong enough to keep the hood from flying up at speed and in an accident.
