Rough running '01 WS6 TA
Could it be the Intake Manifold gasket causing all this stuff? I already bought an O2 sensor so I guess I will just have that installed along with whatever else gets done. Or should I wait, or what? Any advice on the gasket replacement job? I've been told a few different things by different mechanics, as usual. I thought the gasket set was just one pre-cut piece, but one guy says there are actually an upper and a lower piece and that I need to do both. He also says I need to have the coils replaced or something to that effect. I'm in an area where its tough to find a reliable, honest shop for some reason. Another problem seems to be that they see a guy coming with what they consider a "special" car, and they figure I'll do anything, at any price, to get it fixed.
If we know where you live, we can possibly direct you to somebody who can give you reliable advice - maybe even for free. You may also want to search the regional forums.
Best,
fastertransam
If you are low on funds, I would hold back on the new O2 sensor. Change one thing at a time.
Best,
fastertransam
One thing at a time.
The code doesn't tell you how things ARE. It tells you how things WERE. Your code means that at one point in time, the O2 sensor measured a lean condition in the exhaust. The car may be going into open loop or dumping more gas into the engine to compensate for that condition it found.
It is been throwing codes related to the O2 sensor forever, and before the running rough weirdness. I’ve cleared the codes a zillion times and it keeps coming back with them, so its probably reasonable to think the O2 sensor is backed. I dunno. I think I could probably get it done along with the other work. But I hear you about the "one thing at a time" strategy. That’s good trouble shooting practice to figure out exactly what the problem really was. Maybe I’ll have them do the intake manifold, then check the car, and if it’s not running perfectly then do the O2 sensor. Or I guess it could go the other way around. But when the guy sprayed brake cleaner on the manifold it definitely made it miss, so there is something going on there.
The saga continues ha ha.
Best,
fastertransam
