Why or how did I snap the oil pan bolts?
I am trying to replace the rear main seal on my ls1. When I was going to tighten up the rear cover I hand tightened the rear bolts and then went on to tighten the two long oil pan bolts. I read the torque recommendation is 106 pounds. Well, I was going to set the torque wrench to 26 ft lbs and then go to 56 and finally 106. It didn't even make it to 26 when it just snapped. I was able to remove the rear cover and remove the bolts snapped inside the cover, but why did this happen? Is it because I applied medium strength thread locker or put too much rtv on where the cover meets the oil pan?
The following users liked this post:
2001ws6ft (06-21-2020)
Well now you have the painful task of removing those broken bolts from the block. Lessons learned!
Keep this for reference!
http://www.ls1howto.com/index.php?category=1
Do you think I'll have to buy another new rear main seal and gasket? I literally had the cover with the new gasket and seal on for less than 10 minutes when the bolts snapped and I removed the cover. Or is it one of those things that you should replace it every time it's removed.
Feel good - others have lost millions more on similar unit conversion issues: https://www.wired.com/2010/11/1110ma...server-report/
