Sponsored by: CARiD
Sun Visor repair
Old Aug 19, 2005 | 02:51 PM
Brian2006's Avatar
I have run through an identical problem.
Old Aug 23, 2005 | 10:31 PM
2000WS6Vert's Avatar
Ok, I finally had some time to get pics of my fix.
My car is a 2000 convertible.
First off, the bolt I used is an M7 8.8.
I used two different types of washers as the bigger one was needed to fit the size of the spring, and the smaller was need to fit the head of the bolt because the larger one's hole was too big. Make sure the washer isn't so big that it can't fit in the opening on the roof where it came from.
The double washers worked out well as it's extra protection to prevent the bolt from ever unscrewing.
You will need to find the original spring that was attached to the post of the sun-visor. This may require use of a magnet on a wire or some sort of ingenious tool to fish out the spring if it fell down inside the A-pillar.
Also, when you screw all this together....make sure you get the washers pretty well flush with the top of the post. This way the spring can exert pressure on both ends and the sun visor will stay where you move it when in use. Test this by hand before you put it back inside the car as it would suck to hang it back up only to realize it doesn't move.
Check out the pics below....feel free to ask questions.
Attached Thumbnails Sun Visor repair-visor1.jpg   Sun Visor repair-visor3.jpg   Sun Visor repair-sunvisor5.jpg   Sun Visor repair-visor2.jpg   Sun Visor repair-visor4.jpg
Old Aug 24, 2005 | 02:02 PM
Ling_650vette's Avatar
Good idea on a writeup for this.
My passenger visor is on the floor in the back. I was thinking about removing the driver side one and just making a button or something to fit in there for a cleaner look but I might just tinker w/ the fix and see if it helps.
Old Aug 24, 2005 | 02:34 PM
abadss's Avatar
good idea with the fix, my drivers side fell one day and hit me in the nuts so i bought a new one on the board from a vender, was like $15 shipped.
Old Aug 25, 2005 | 02:19 AM
Aaron's 00 TA's Avatar
Thanks for the write up. I'll have to find the spring though. I'm sure it is lost, since i was in the middle of doing some shake down runs when the visor fell.
abadss- Who sells them for $15? Or was that a one time thing?
Old Aug 29, 2005 | 07:56 PM
The spring probably flew down into the A-pillar or is still stuck in the frame of the windshield. I removed the trim around both and I had a good flashlight. I was able to find it and with a hangar with a magnet on the end, I was able to fish out the spring.
Also, if one of your visors has fallen off....be sure to do this fix on the other one right away....as it's not far behind from wearing out and falling off.
Old Aug 29, 2005 | 08:40 PM
Trojan35's Avatar
Originally Posted by jlaw
This exact thing just happened to me. I was driving and the damn thing just fell right on my lap. I was less than amused, but my gf found it hilarious. =\
That happened while I was driving. Except it was the passenger side one and it fell into her lap. I found it hilarious because I've wanted to take'em off for a long time. She's pissed because she wants her vanity mirror
Old Aug 29, 2005 | 09:40 PM
I ended up fixing mine without the spring. I used a couple washer in place of the spring and used an old interior screw from a car that had the built in washer. It works like a charm.
Old Aug 29, 2005 | 10:19 PM
Cop Car's Avatar
have all you guys had CD holders on your visors or been putting them up and down a lot?
Old Aug 31, 2005 | 12:48 PM
A friend of mine had both of his fall off and it was only a year old at the time. He took it to the dealership three different times!
I have a convertible and I use a sun shade everyday (I live in South Florida). Plus when I put the top down you have to slide the visors out of the way to engage/disengage the locks. So I use mine an awful lot and they just fell off 4 months ago on a 5 year old car.
My point is, some are made better than others, but regardless if yours is broken or not...they WILL break so you might as well do this fix.
Old Sep 11, 2005 | 04:41 AM
I've never had a CD holder, but that doesn't mean the previous owner didn't though. I use mine alot.
Old Sep 12, 2005 | 11:22 PM
  #32
LS1MONSTER's Avatar
Mine driver side fell out awhile ago.. I took that visor for granted.. Its a MAJOR PAIN IN THE ***.. driving with the sun in your eyes. POS GM parts!
Old Sep 13, 2005 | 02:58 PM
  #33
2KThunder's Avatar
... I was thinking of just compressing the spring, pushing the washer down, and bending the edges of the joint end outward to hold it in place.
Thats what I tried, but the metal is pressed and very flimsy/thin. I couldnt get it to hold, I tried welding it too, but whatever metal it is wouldnt weld, maybe cast iron?
Old Sep 13, 2005 | 03:41 PM
  #34
Speed Density's Avatar
hashtagBMW
Wow i thought mine was shitty, LOL, im just going to remove em, but then i got nowere to put my shades or garage door opener, im lazy i dont want to be looking for ****. haha
Old Sep 13, 2005 | 09:24 PM
  #35
12Gauge's Avatar
I used these pics to guide myself. http://www.my2kta.com/images/visorfix/
Old Oct 2, 2005 | 11:20 PM
  #36
P Mack's Avatar
I had this happen a few days ago and I hardly ever use the visor (passenger side). Are you guys tapping threads in the metal or using self tapping screws? Or do your visors already have threads cause mine doesn't seem to have any.
Old Aug 24, 2007 | 02:11 AM
  #37
3.8SFITURBO's Avatar
2000WS6VERT- Great write up!
Mine (passenger side) fell off the other day, Little to no use ever 60K mile car and no weight on it. I'm gonna try the repair trick, Hope it works!
Old Aug 24, 2007 | 03:08 PM
  #38
Glad I could help!!!
It's been almost 2 years since I did both of mine and they've had no problems since!
Old Aug 24, 2007 | 05:50 PM
  #39
Formula413's Avatar
I posted some pics of one I fixed in another thread a while back:
https://ls1tech.com/forums/general-maintenance-repairs/669705-ds-sun-visor-fell-my-lap.html
