Sponsored by: CARiD
Starting Issue!!!
Old Jan 1, 2022 | 08:37 PM
rwhitaker04's Avatar
Default Starting Issue!!!
So I had to remove my steering column and undid all the wiring. Now I reinstalled my column I get no crank. I get power to everything, and fuel pump turns on. Vats are turned off, I’ve checked neutral safety. All my connections appear to be connected…any ideas what to check..I’ve spent 2 days on trying to get this thing to start…
99 camaro ss
Old Jan 2, 2022 | 06:30 PM
jetech's Avatar
Veteran: Air Force
I don't know what the vehicle is you are working on is but, here is a schematic for 2005 GM truck
Are you getting power through the start relay? That should be sending power to the starter solenoid and spinning the starter
Old Jan 3, 2022 | 08:58 AM
wssix99's Avatar
Save the manuals!
The key cylinder actuates a rod in the column that presses a plunger on the starter switch bolted to the bottom of the column. I would make sure that rod is engaged properly, that the switch is working, and that the electrical is hooked up to it.
If you had to undo the pins on the electrical connectors (or even if you didn't), I would check to make sure all the wires in the column connector are seated properly and in the correct positions. I think we have a sticky in the Electronics section that lists them.
Old Jan 3, 2022 | 09:57 AM
WhiteBird00's Avatar
Ungrounded Moderator
Is the SECURITY light on? If it's an f-body, VATS can't be "turned off". You can program the PCM to ignore the missing fuel enable signal but you can't program the BCM to activate the starter relay - you have to do a VATS bypass or rewire the starter relay ground.
Old Jan 7, 2022 | 10:32 AM
security light works as it should....flashes when not armed, solid when armed, goes off when key is in the hole. ill have to double check my hptuners but im sure it says none for vats control
Old Jan 7, 2022 | 10:48 AM
We're talking about the security light in the instrument cluster (the word SECURITY) not the red alarm LED on top of the dash. The security light should go on solidly for a few moments when first turning on the ignition (the bulb test cycle) and then go out and stay out until the next time you start the car. It's a competely passive system and there is no arming or disarming as there is with the optional factory alarm system.
Whatever your HP Tuner says, it can't completely disable VATS because it can only program the PCM but VATS is in the BCM, which is not programmable. As mentioned, your tuner can tell the PCM to ignore the lack of a fuel enable signal from VATS in the BCM (that's what it considers turning off VATS) but it can't change the way the BCM prevents the starter relay from tripping to run the starter. The only way to do that is with a true VATS bypass or by rewiring the ground wire on the starter relay.
Old Jan 7, 2022 | 11:30 AM
So where would I re wire the ground wire on the starter relay to?
Old Jan 7, 2022 | 08:13 PM
Got it figured out, was a faulty ignition switch
Old Feb 8, 2022 | 08:13 AM
alawasdon's Avatar
hello
but the BCM cannot be programmed to engage the starter relay; instead, a VATS bypass or rewiring of the starting relay ground is required. turkish citizenship requirements investment in turkey
Old Mar 5, 2024 | 10:47 PM
JohnGrandjean's Avatar
thank the lord for this information! I was about to do the exact same thing you you stated after chasing schematics and wires for days… I was about to direct ground the relay to bypass BCM and on one last hunt found your reply to confirm. Thank you sir!
