Sponsored by: CARiD
Cammed LS1 - Oil preference?
Old Jan 28, 2022 | 08:55 PM
Revo1's Avatar
Default Cammed LS1 - Oil preference?
New to the cammed life... Is my car going to divorce me if I put OE spec oil in it?
Old Jan 29, 2022 | 02:31 PM
wannafbody's Avatar
I was told by my mechanic to run a high zinc oil. Amsoil makes ZRod oil. Valvoline makes a high zinc oil. Or you could use a zinc additive.
Old Jan 29, 2022 | 03:19 PM
pdxmotorhead's Avatar
Zinc is most important in a flat tappet application, if your running rollers it makes way less difference.
The cam is the piece that surface hardens the most during break in.
After that is the tips of the valves and rockers. Old school cast iron rings also needed to surface harden but
these days that's not a issue..
Any quality oil will do the job especially if you don't let it go to crazy high miles..
Old Jan 29, 2022 | 03:38 PM
Revo1's Avatar
Thanks fellas I appreciate it
Old Jan 29, 2022 | 05:07 PM
RedXray's Avatar
EPA has cracked down on high zinc % in motor oils. Like posted above modern engines don't require high zinc levels like yesteryear. Racing oils with a high zinc concentration can also clog cats when used in a street application. If you're looking for a good oil with a slightly higher zinc level try the Mobil 1 Euro 0W-40. Testing shows it's closer to a 0W-35 viscosity. It's stocked at Walmart at a good price too. I've used it for years in my cammed LQ9 with zero issues.
Attachment 712332
Old Jan 29, 2022 | 05:56 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
^ Excellent recommendation above; M1 0W40 Euro. It does have a bit more zinc (ZDDP), plenty for any roller application IMO. I use this oil in every LS1/Gen III I've owned, cammed or not.
I use the much higher ZDDP content Valvoline VR1 in my old flat tappet SBC, but that's just not needed for an LS1 application IMO.
Old Jan 29, 2022 | 07:32 PM
Cajun ELESS-ONE's Avatar
Hydrologic rollers aren't as picky about oil. If it's under 100k miles, factory weight oil is fine. The more important thing is regular oil and filter changes. 5-6k miles. Like stated above, Mobil one is a good brand. Iv also seen alot of people use rotella full synthetic in there ls1s and other gas motors and swear by it. Iv used it in my lt1 and ls1 with no issues. Do your own research and see what you feel it best for your situation.
Old Jan 30, 2022 | 09:47 AM
99 Black Bird T/A's Avatar
Ran an XER cam for 132,000+ miles with Mobil 1 5w-30 and later Mobil 1 5w-30 high mileage. No issues or problems. Changed oil as needed ~5,000 miles and used a high quality oil filter.
Best advice is check oil level regularly and top off oil if it gets low.
Old Jan 30, 2022 | 10:38 AM
Tyler Dietzenbach's Avatar
This. Any oil/filter changed at the proper intervals will be fine.
Old Feb 7, 2022 | 10:40 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Thumbs up
I agree 100% with this, I live in a warm climate, and I use 10w-40 synthetic oil, and have no issues whatsoever.
