Grinding noise when turning
It started when I had all the bushings and ball joints replaced a couple of years ago. We recently replaced the right upper ball joint, thinking it may have been the culprit. It seemed to help for a while, but now it's back to the same old grinding.
Appreciate any help!
This occurs when cranking to the left only. My buddy who owns four shops and his techs have no idea. And otherwise the front end is completely tight. Still poking around for ideas ...?
is this a noise as the steering wheel is being turned?
Or is it a noise that occurs while turning, even if the steering wheel is stationary?
Ball joints, steering components are not going to cause a rotational noise. A ball joint with no grease can cause a squawk as the knuckle turns or as the suspension articulates. It can also cause a knock over bumps. A steering rack could cause a noise as the wheel is turned, but not common.
If I am understanding you correctly that this is a rotational type scraping/grinding noise that occurs in motion, while turning, and is more audible at slow speeds I would do the following:
1. Recreate the noise in a parking lot while someone is listening from outside of the vehicle. Sometimes noises like this can kind of echo and you can be tricked about which corner the noise is coming from. Identify the corner positively first.
2. Jack up the vehicle or place it on a lift.
3. Not necessarily going to locate the source of your noise, but every time I lift or jack up a vehicle, I do the following:
5. If you still have not found the noise, pull the wheel. Look very closely at the brake rotor. The friction surfaces AND the edges at the outer diameter. You are looking for any shiny spots where something may have been rubbing. This could be a piece of brake hardware that is out of place in the bracket, a wear sensor/squeeler that is bent further inward than it should be, a place where the backing place is rubbing. If you don't see anything on the rotor, still look at the clearance of your caliper braket and such to the rotor. Keep in mind that the rotor may not be sitting square with the hub without the wheel on
6. I have heard many things described as a "grinding". Another thing to check would be for any obvious rub marks on the tire or vehicle where the tire could hit it.
7. Not pertinent to your vehicle, but if this was a front wheel drive application, I would look closely at the axle shaft for something like a broken sway bar link that is rubbing against it.
I hope this helps! If this is not the type of noise you were describing, please clarify and I will give the best advice I can.
The noise occurs when turning the steering wheel to the left at slow speeds, like when turning to pull out of a parking space. There is no play in the steering, wobbliness, noise, or vibration going down the road. The front end is tight.
