Sponsored by: CARiD
Compression / timing
Old Apr 15, 2022 | 03:52 PM
Hidden1's Avatar
Default Compression / timing
What is the best techniche to use to know if your engine is in compression stroke or exhaust stroke as you manually turn the crank .. ive seen the a balloon technique or a straw..but want to know best method..maybe my compression tester?
Just put timing chain on [ dots lined]
Thanks
01 dakota 3.9 2wd auto
new chain.
Also is the crank bolt to be at 135ft lbs or 185?
If it started right up on 1st start [[AND IT DID ] am on on track as far as compression stroke ?
thanks
Old Apr 18, 2022 | 06:55 PM
jetech's Avatar
Veteran: Air Force
LOL....This is a GM forum. I have just put my finger over the #1 spark plug hole while turning the crank. As for the bolt spec...the internet is your friend
