Rear driver side wheel wobbles while driving
Can you get one of those inexpensive HF dial indicator on a magnetic base and start checking for run-out? Check the rotor w/o the brake caliper installed, and go from there.
Since you already replaced the axle shaft...and it bent again?! Is that I understood? Was that a new axle shaft? Did you get a bad one? Could the axle housing be bent? Not sure how you would check that? Maybe with a 6' level? I have seen axles break at the plug welds into the differential, but that's more like from torsion loading. I think the impact of the wheel on a curb would cause bending stresses on the axle shaft.
Jack up the rear and spin it to see if you can figure out what's bent or out-of-round.
I understand your frustration. But at this point, I'm going to say just carry on and try to fix it yourself.
