Sponsored by: CARiD
Window loose/ janky
Old Feb 21, 2024 | 09:07 AM
blackbirdls1's Avatar
Default Window loose/ janky
Before i take the panel apart, what could be the culprit that i'm hearing on the video? It's def loose feeling when closing the door as well. Passenger side doesn't do it.
File Type: mov
Old Feb 23, 2024 | 08:57 AM
Noone? Only 1 view?
Old Feb 23, 2024 | 11:37 AM
bleepster's Avatar
81 views - but anyway - if I remember correctly - there are "guides" in the door - those may need adjustment. they look like this. wont know for sure until you open it up
Old Feb 23, 2024 | 04:36 PM
wssix99's Avatar
Save the manuals!
^ Those guides do not contact the glass during most of the movement. They primarily keep it off the outer seals (so it doesn't drag) seals as the window is half-way up.
The inner door panel needs to come off to find out what's going on. The regulator rivet holes could be worn or the rear inner roller (The roller attached to the glass bottom frame riveted to the glass.) could be broken. Both of these are common and will cause the window to loosen up.
Old Feb 23, 2024 | 08:08 PM
How bad is it to fix? I will take it apart this weekend.
Old Feb 24, 2024 | 08:13 AM
wssix99's Avatar
Save the manuals!
It depends on what the problem is, but it will probably not be an overnight fix. If you are good with tools, you can probably do this yourself. If not, you'll need the help of a body/mechanical shop.
Please take the door panel off, peel back the plastic on the door. Check out the roller, check out the regulator mount. Take pictures, post and report back.
Old Mar 10, 2024 | 05:51 PM
Reporting back, there seems to be some play on this bullet type metal piece on the tracks. Is that normal? Everything else seems tight.
Old Mar 11, 2024 | 08:39 AM
wssix99's Avatar
Save the manuals!
The last picture is of the rear roller. It's common for that part to crack and then break clean. You want to make sure that isn't happening. (I can't tell from your picture.)
Old Mar 11, 2024 | 08:56 AM
I'll take more photos, but i think that's the piece that's loose. I saw someone rig up a screw and washer setup as a replacement.
Old Mar 11, 2024 | 10:36 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
I believe this is the thread, post #7.
https://ls1tech.com/forums/general-m...dow-guide.html
Old Mar 11, 2024 | 10:46 AM
I see t thanks, Does that roller come out easily?
Old Mar 11, 2024 | 05:34 PM
Well it’s definitely the rear roller. It’s not fully broken but it won’t stay in its place when movement is done.
Old Mar 11, 2024 | 06:59 PM
wssix99's Avatar
Save the manuals!
The bolt and washer is a band-aid that buys time.
Personally, I am a fan of welding the stud to the bracket to seal up the cracks. (or taking it to a mechanical/body shop that can do it safety without burning the car up)
Old Mar 12, 2024 | 12:38 PM
In December it'll be going on 14 years with no noises or unusual window movement, I'd say it bought a lot of time.
Old Mar 12, 2024 | 02:24 PM
Need parts and sizes. I do have the option to have it welded also.
Old Mar 12, 2024 | 03:16 PM
screw is 1/4-28 tapered head socket head cap screw,thick washer(well greased to minimize metal to metal contact) used to duplicate large roller and has a ID larger than the screw to allow 'swivelling',large thin flatwasher to prevent pullout thru the damaged hole,1/4-28 locknut.
Old Apr 14, 2024 | 06:05 PM
Ended up having a buddy tack weld it on. Had to adjust the window stops slightly after to get everything aligned. No more loose window.
Old Apr 20, 2024 | 06:37 PM
I lied window is loose some. Unless all the way raised up. Any ideas?
Old Apr 21, 2024 | 01:40 PM
wssix99's Avatar
Save the manuals!
I would first compare it to the other side of the car. If its different, then something is broken or loose. (I'd check your friends welding job first!)
Old Apr 22, 2024 | 02:13 PM
The stud is tight. Ugh
