Sponsored by: CARiD
Thermostat swap
Old Aug 26, 2024 | 01:03 PM
KobeGigi's Avatar
Default Thermostat swap
Going to swap my thermostat on my 01 Ta, do i refill with just Coolant? Or 50% DEX Coolant & 50% Water?
Old Aug 26, 2024 | 02:08 PM
Finkledbody's Avatar
Use 50/50 dexcool or any HOAT (semi organic)
or use distilled water with full strength coolant mixed to 50/50.
or fill back up with straight distilled water and pour a bottle of Redline water wetter.
Personally I use O’reilly gold bottle mixed with distilled water and I add the bottle of water wetter.
Old Aug 26, 2024 | 04:22 PM
KobeGigi's Avatar
Do i have to turn the heat **** on?
Old Aug 26, 2024 | 08:11 PM
the_merv's Avatar
Veteran: Air Force
The what?
Old Aug 27, 2024 | 07:08 AM
bleepster's Avatar
it would be helpful to turn the heater on high while filling
Old Aug 27, 2024 | 04:38 PM
KobeGigi's Avatar
This one?
https://www.oreillyauto.com/detail/c...dex+cool&pos=1
Old Aug 27, 2024 | 05:37 PM
the_merv's Avatar
Veteran: Air Force
4th Gen Fbody doesn't have the little shut-off valve on the Heater Lines like the earlier cars do.
Old Sep 3, 2024 | 08:21 AM
Afolly's Avatar
For your 2001 Trans Am, you should use a mixture of 50% DEX-COOL antifreeze and 50% distilled water. This ratio ensures proper cooling system performance and protects against both freezing and boiling. Make sure to properly bleed the system of any air pockets after refilling to avoid overheating issues.
Old Sep 5, 2024 | 08:03 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Thumbs up
^^^^This^^^^, and don't forget to burp the system. I use a 50/50 mixture of Dex cool and Distilled water, and a bottle of Purple Ice water wetter, with a drop of lemon juice for flavor.
Old Sep 5, 2024 | 04:44 PM
the_merv's Avatar
Veteran: Air Force
Some of you all should really understand how cars work instead of spouting **** your uncle daddy told you.
