Steering column pains
I also have a solid airbag light even though both original airbags are installed. A couple of years ago I took it to the dealer and they found stored codes B1015 & B1021. Driver & Passenger deployment loop high resistance. Dealer claimed "Needs driver & passenger airbag.".I cannot find any information that indicates whether the airbags would still function. Driver side is relatively easy swap, but it looks like driver is a PITFA to swap. I wouldn't mind keeping those features if replacements are available and the rest of the SRS system works.
My first priority is correctly operating wipers, then tilt, then SRS. Does anyone sell complete steering column assemblies, at least from the firewall to the airbag area? Everything new except for steering wheel & tilt lever, with matching keys, etc? If not where do I start? Wiper motor? Wiper switch? I ordered out of stock PN 12367295 off Amazon. I'm looking for the easy button to fix everything in the column even if it costs extra.
The only part of the multi function lever that does anything is the button. All other functions are controlled by the switch in the column.
Here is a thread I created when I replaced mine: https://ls1tech.com/forums/general-m...mn-repair.html
I didn't get all the pictures of actually replacing the switch. It took all day and involve a lot of contortions, little pins and swearing.
This guide has more info: https://www.crankshaftcoalition.com/...ck_Rebuild.pdf
This looks similar, but it says only for Jeep
https://www.oreillyauto.com/detail/c...tch/std0/ds572
I found these but they look nothing like page 39 of the Jazzman guide.
https://www.classicindustries.com/pr...s/1995963.html
https://www.oreillyauto.com/detail/c...?q=2TSS2&pos=0
The instructions you are looking for are in Section 2 of your Helm (GM Factory Service) Manual with the detail on the steering column.
I suggest using a GM parts lookup to find the part number for your switch and having it on-hand before you start a repair. There are many part numbers, depending on your options for this part and you may need to wait to get it. (So, you don't want to have your column all apart waiting 2 weeks for a switch.)
I think you will find the diagrams and instructions in your manual severely lacking. The Jazzman guide I linked above is invaluable.
I just looked back at my records from my repair in 2011 and it turns out I totally gagged at the price of a GM wiper switch and went for a Duralast SW883. That switch served me well, but it looks like that part no longer exists. (The manufacturer was actually Wells) So, I guess the aftermarket must have been fine on that. I did purchase the AC Delco Wiper Switch ARM 25140743 and would have sprung for that part since the screen printing was a visible thing. (The white lettering had worn off my original switch after 10+ years of use.)
I'm sure someone at a dealer could look up the original GM part number but we may be too far gone. GM Parts Giant has a part listed for my car. You may be able to find a part number that way and some comps, but this one looks hard to find... https://www.gmpartsgiant.com/parts/g...)&location=pd:,
For the cruise control:
- The LED cause could be one
- The brake or clutch pedal sensor could be another
I could opt for something like this, which may incure more labor expense but likely is less expensive overall.
https://www.steeringcolumnservices.c...t-housings.php
I have always expected that the tilt slop was due to people moving the tilt frequently and was not something a single long-term owner would come across.
Its painful, but you may have to move the Ferrari out of the garage and drive it around on the street for a bit while you get this taken care of.
