How to do an oil change?
well ... my question is ... is there any specific i need to know?
Well like where exactly is the oil pan? Do i have to torque the nut? If so how much?
Sorry tried to search around ... just second time ever changing oil. (first time owning a place with a garage)
thanks
EDIT: the socket is like 15mm i think, i 'm 90% sure thats what i used atleast
Install University has tons of great information, including an illustrated guide to changing your oil.
http://www.installuniversity.com/ins...oil_change.htm
-Mike
i dont think my torque wrench goes that low. oh well.
You gotta start some where. Just make sure you have something to catch it with when you get the nut out.
-while the drain plug is out, make sure to clean it off real well. there is a magnet on the end of it which will almost certainly have some nice black goo on it so remember to clean that crap off before you put it back in.
-when you tighten the drain plug, DO NOT overdo it. don't bother torquing the plug. get it finger tight and then give it a soft 1/4 turn with a SHORT wrench/ratchet. it's pretty easy to strip the threads in the oil pan and you DO NOT want to do that. i can't stress enough how important it is to take your time on this step. make sure the plug goes in nice and straight too so u don't cross-thread it.
-pull the oil cap off before reinstalling the drain plug. usually releasing the seal from the top will speed up the flow of oil out the drain hole.
-when you install the filter, lube the gasket around the top with a little oil. this will lubricate the gasket and make sure it doesn'y bind up when you twist it down against the filter seat.
-invest in an oil filter wrench. when properly installed, it should be EXTREMELY difficult to remove the filter by hand, especially if it doesn't have some grip tape or something on the bottom like the Frams do.
that's about all i can think of. good luck...
