Any Suggestions?
I think the others are right. Dealership....At least for the diagnosis.
Easier said than done, I work every day from 8 in the am til 5 pm and then off to my second job from 5:30 -12. I'm a working girl
I swear... I think some people just ignore my posts.
Thanks Hawgs, just got home from work and i'm reading all post now, i will be workin on this whole mess tomorrow and through out the weekend! Have a good one guys and I'll let you know what i turn up on Monday!
Thanks Ross! I will be doing that when I get off work!
I did not say anywhere in this thread that reseting the PCM will fix her problems. People were suggesting that it might be from a clogged cat... so I suggested reseting the sensors via reseting the PCM so the car would run right while the computer is still relearning everything and you could rule out the possiblity that it is a clogged cat. If she reset the PCM and had no trouble codes and the car still felt like it had no power then the problem might be from a clogged cat (though I seriously doubt it). Reseting the PCM will take it out of "limp mode" and you will be able to tell if it is a sensor problem or a mechanical problem somewhere.
Just to let YOU know... reseting the PCM per the directions I gave will in fact clear problem codes, and I never suggested removing the battery cable.
Lord help anyone that brings their car into the dealership where this guy works...
