radiator lights on but fluid levels fine?
i have a 97 ss and lately my radiator light is periodicly lighting up but when i check the fluid level its fine. can anyone tell me why this is happening and how i can possibly fix it. my only guess is that the sensor is bad but not sure. thanks.
http://shbox.com/1/low_coolant.jpg
Its really easy to remove. Here are the instructions
http://shbox.com/1/low_coolant2.jpg
it may be possible that the coolant is actually below the sensor when the light comes on, but when the coolant heats up, it expands and rises back above the sensor...and that may be when your checking it....just make sure you check it when the engine is dead cold to be sure this isnt the problem....
ya ill look into that thanks. i think ill probably have to change the low coolant sensor because i checked the coolant level in the morning before i drove it and the level was fine but the light still came on. i just hope i dont screw anything up when i go about changing it, but thanks for the instuctions ill use them for sure.
