Sponsored by: CARiD
Oil Filter
Old Mar 20, 2005 | 06:22 PM
Yenko's Avatar
Default Oil Filter
Ive been searching around the fourms, and i know for sure that German Castrol 0w30 is the oil of choice for most members.............however im trying to find patmans recomendations for an OIL FILTER.......please help!!!!!!!!!!1
Old Mar 20, 2005 | 06:36 PM
XuhQshinR's Avatar
I know there are better ones out there but I stick with the Ac/Delco PF59 and seems pretty good to me and I save from paying over $10 on an oil filter.
Patman has a good writeup here: http://www.tfbm.org/faq/oil-filter.html
Old Mar 20, 2005 | 06:39 PM
LS1Adam's Avatar
correct me if this is a bad suggestion but how about Pure One?? I just got one myself two weeks ago.
Old Mar 20, 2005 | 07:15 PM
BriancWS6's Avatar
Go with the K&N HP2006, it's the long one, works great.
Old Mar 20, 2005 | 10:08 PM
black00TA's Avatar
purolator pure one filter. awsome filter.
Old Mar 21, 2005 | 12:17 AM
ZR2877's Avatar
I did use the long Napa gold but now I use the short Napa gold because my car is lowered. It's a great filter from what I have read.
Old Mar 21, 2005 | 02:00 AM
2MuchRiceMakesMeSick's Avatar
I pay a few more bucks for a K&N oil filter.
Old Mar 21, 2005 | 02:06 AM
Yenko's Avatar
Just Finished, I used a K&N oil filter with Mobill 1 5w30 Motor Oil, because the german castrol is nowhere to be found in my area..............
Thanks for your all your input, im totaly **** when it comes to this car so i had to get it done before the work week started...............thanks again.
Old Mar 21, 2005 | 02:18 AM
1 BLOWN V8's Avatar
Wix filter for me. But next oil change I may go with a mobil 1 oil filter, since I am using mobil 1 oil.
Old Mar 21, 2005 | 03:02 AM
TheBlurLS1's Avatar
That's what she said...
the purolator and wix are good filters, with the purolator having a bit of favor.
the fram is the worst you can use, theres a thread in the external engine section as to why. i had been using them since i bought my car, but no more after this
do they make a long type purolator?
Old Mar 21, 2005 | 09:37 AM
Tommy's dad's Avatar
read the thread on fram and you will want to avoid it Another vote for purolator as well.
Old Mar 21, 2005 | 10:22 AM
SSCam99's Avatar
I use the K&N. I'm happy with it. I think its worth the extra couple dollars.
Old Mar 21, 2005 | 11:40 AM
snake charmer's Avatar
K&N is the filter that my car uses. May be a little bit more than some other filters but its not like I buy one every week. Mobil One also makes a good filter to match thier oil.
Old Mar 21, 2005 | 11:12 PM
BriancWS6's Avatar
Good choice, next time go with the Mobil 1 0w40 European formula, it's the viscosity of choice out of the Mobil 1 oils, Patman verified
Old Mar 21, 2005 | 11:26 PM
MM98's Avatar
I use an AC Delco PF46 along with Mobile 1 10w30, no problems with 95k on the clock.
Old Mar 22, 2005 | 12:49 AM
GreekGator's Avatar
Wix filters used here
Old Mar 22, 2005 | 10:19 AM
demonspeed's Avatar
It's not mine! woo hoo!
I use the standard length K&N HP1007 (5.5 quarts). If you want to run the longer K&N HP2006, then make sure you run 6 quarts. I personally use Mobil 5w30 because I'm too lazy to look for the German Castrol, and quite frankly, I've used the Mobil for so long in both my LS1 cars, that I'm not really worried about it.
Old Mar 22, 2005 | 05:45 PM
ws6dude's Avatar
I just put M1 0W40( not the euopean blend) and K&N HP 2006, it really lowered the noise
