Sponsored by: CARiD
wiper blades
Old Mar 26, 2005 | 09:28 PM
TnTrk53's Avatar
Default wiper blades
How long are '98 camaro wiper blades?
Old Mar 27, 2005 | 01:01 AM
Bones SS's Avatar
If they're the same size as my '02 they are 24"
Old Mar 27, 2005 | 02:21 AM
ACW's Avatar
ACW
Looks like 24" for both sides. For future reference, TireRack.com does wiper size lookup. http://www.tirerack.com/accessories/...d=wiper+blade&
Old Mar 27, 2005 | 01:24 PM
TnTrk53's Avatar
Thanks guys I need to pick 'em up on the way home but I'm in my truck.
Old Mar 27, 2005 | 02:57 PM
demonspeed's Avatar
It's not mine! woo hoo!
FWIW, I run Silblades. They last a long time and have a nice clean and streak free wipe. They also lay the PTFE coating on the windshield so the water will bead off like Rain-x.
Old Mar 31, 2005 | 12:06 PM
fastmatt98's Avatar
Just replaced mine yesterday.
Old Mar 31, 2005 | 12:14 PM
PredatorZ's Avatar
Okay, on the topic of glass in general... I have a question, maybe someone out there has had a similar problem.
The windshield of my 88 IROC gets a "film" on the inside. I can clean it and it looks good for a week or so, then if you run your finger across the glass you can tell that it is covered by something. I've even had the glass replaced, so it is brand new and yet I still get this strange film build up on the inside!
Any ideas?
Old Mar 31, 2005 | 04:44 PM
demonspeed's Avatar
It's just a mix of dirt, probably some coolant, etc. When you turn your heater on, it's blowing all the crap up on the windshield that settles down in the vents.
Old Mar 31, 2005 | 09:24 PM
ACW's Avatar
ACW
Any ideas?
Eagle One 20/20 Auto Glass Cleaner Works wonders.
Partly the film can come from stuff in the vents getting blown onto it like the previous post said, but I've read that the main source is the chemical particles that evaporate out of the plastic/vinyl (and probably some leather treatment stuff too) in your car's interior.
ArmorAll apparently makes the film much worse than it would be without it having been used on the interior. Also if you use sunshades in your windshield whenever you park outside, it should reduce the film's accumulation rate since the sun won't be 'beating down' directly on your dashboard anymore.
Old Apr 8, 2005 | 09:17 AM
Mr Incredible's Avatar
As I understand it (from reading something in the depths of the past), the film is caused by off-gassing of the plastics in your interior. Even if you cleaned the heck out of everything inside your car and the inside of the glass, and then parked it in a dark garage, a film would still develop.
Personally, I believe there's a conspiracy between the plastics manufacturers and the window cleaning industial complex.
