Sponsored by: CARiD
headlight problem
Old Mar 27, 2005 | 05:50 PM
cbrrmike's Avatar
Default headlight problem (tried searching)
hey guys i have a couple questions about the headlights on my 99 transam.
when i shut the headlights off they still go up and down fine but once they close they make a LOUD grinding noise for a few seconds.
i am assuming this is the gear or the motor, but im wondering if i could be wrong, and where i can get the parts so i dont have to replace the whole assembely.
about the same time this started happening, my headlights started popping up and down when i hit my keyless entery, or even if i lock the doors from inside the door..........any ideas on that?
they also come up when i turn the switch to the middle (taillights and fogs) position on the switch....
any help will be greatly appretiated
mike
Old Mar 27, 2005 | 07:35 PM
98FormulaWS6's Avatar
Click Here
Go to the above link it will tell you everything about your problem and how to fix it for good. The keyless entry problem I had the same problem and was fixed when I changed out the gears for the ones in the link above. Everything works fine now. The gears that comes stock are horrible. Good luck.
Old Mar 27, 2005 | 08:12 PM
VIP1's Avatar
Copy & Paste Moderator
If you checked in the "Pontiac Firebird 1967-2002" section, you would have seen that this is a stickie:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
There is a free fix and a brass gear replacement. The brass gears are at the top of BFranker's page and the free fix is lower down.
Hereare a couple threads specifcall about it:
https://ls1tech.com/forums/showthrea...eadlight+noise
There are more threads, but these specifically mention the headlights going up and down with the alarm. I specifically searched for "headlight noise".
Old Mar 27, 2005 | 08:15 PM
Danny2tek's Avatar
read my sticky!
Old Mar 27, 2005 | 09:55 PM
cbrrmike's Avatar
sorry.........searched the wrong place. thanks guys
Old Jun 9, 2005 | 12:01 PM
98whiteT/A's Avatar
Hey im having the exact same problem!!!!!!!!!! mine is a 98 and having to take it to the dealership to get it fixed!!!! everytime my headlights go down one of them makes a horrible grinding noise...yes they even do it when i lock the car...this sucks!!!!
