Sponsored by: CARiD
2000 trans am - overheating
Old Jun 7, 2005 | 06:29 PM
Johnnyger's Avatar
Unhappy 2000 trans am - overheating
Today, while sitting idling, the "check guages" light came on. I wasn't low on gas, so I looked at the other guages. The temp was in the red. As I drove, it dropped some, but everytime I stopped idling, it pegged up again. I stopped at a garage, and after the car cooled enough, he popped the cap. When he started the car back up, the anti-freeze started pouring out. He eventually added water. The guy recommended changing the radiator. The car only has 55,000 miles on it and has been well maintained. I decided to take it home and think it over. Interestingly, the temp didn't go way up on the way home. I tried letting it idle in the driveway when I got home. It started getting kind of high, but settled down and actually dropped a little. (the book says that if the coolant/water mixture is wrong, the temp won't read right. Is that so?)What running temp do you all see during the summer? (It's real hot here in Florida). My Camaro used to almost hit the red before the fans would kick on and cool it. This guy quoted me about $600 for the job (he also recommended changing the thermostat). Any input here would be greatly appreciated. (BTW, I'm a newbie. Hey to all of the TA lovers out there!).
Old Jun 7, 2005 | 07:30 PM
Bird Man's Avatar
Check your thermostat first.
Old Jun 7, 2005 | 07:43 PM
Johnnyger's Avatar
Wouldn't it just overheat if it was the thermostat? (as opposed to the temp going down when I drive, etc?)
Old Jun 7, 2005 | 11:53 PM
ACW's Avatar
ACW
The stock thermostat is supposed to begin opening at 87°C (188°F) and be fully open at 97°C (206°F).
There's a variety of other possible causes of overheating, not sure right now what else to try telling you.
Old Jun 8, 2005 | 06:40 AM
Mighty Wings's Avatar
Make sure your radiator fan is working. The fan is there only to cool the radiator at low to idle speeds. Once you get going, the wind deflector underneath the front bumper moves enough air through the radiator to keep it cool.
Old Jun 8, 2005 | 10:19 AM
iansane's Avatar
Are the airdams a huge part of the system like thirdgens? I know if a thirdgen bird loses its airdam it'll overheat in a few minutes?
Old Jun 8, 2005 | 11:00 AM
redarrow's Avatar
Sounds like a fan quit working on you.
Old Jun 8, 2005 | 04:36 PM
2K2WS6TA's Avatar
IIRC the airdam is a big part of the cooling system, it sounds like this is your problem, crawl under the front and look for the airdam that's supposed to be there.
The sympoms you describe are pretty much what happens when you lose the airdam, temp @ idle is fine, but once you start driving it just keeps rising
Old Jun 8, 2005 | 05:05 PM
Angus's Avatar
It wouldn't hurt to put in a better/lower thermostat. Check to make sure the coolant is flowing in the radiator once the thermostat opens up as well as your fan kicks on.
Old Jun 8, 2005 | 09:31 PM
Johnnyger's Avatar
Thanks, fellow bird lovers! I had to bite the bullet and take it to the (gasp) dealer today. It was OK driving to work this morning (although a little hotter than normal, maybe 225). Just as I got to work, it pegged all at once (probably because the guy yesterday filled it with water). Water was coming out of the reservoir. I managed to drive it to the dealers (later in the day), still runnung about three quarters of the way up (225-235?). Pray for me!
Old Jun 8, 2005 | 09:32 PM
Johnnyger's Avatar
It was the opposite of that. Not bad while running, really high at idle.
Old Jun 8, 2005 | 10:21 PM
2K2WS6TA's Avatar
Well you might also have some sludged up dexcool in there,(assuming you run dexcool) so a flush and refill will hopefully fix the problem.
Did you manage to get a look at the inside of the radiator, and if you did, did you notice some brown sludge looking stuff (about the consistancy of wall paper paste) that would be dexcool gone bad
Happened in my Blazer @ about the same mileage as you had, a flush and refill and it was fine. So hopefully that'll be the case with your T/A
Old Jun 8, 2005 | 10:56 PM
Johnnyger's Avatar
The dipstick in the reservoir had a funny looking color at the bottom, kind of yellowish. I'll see what the dealer tells me tomorrow. If they try to pull anything, I'll bring it home!
Old Jun 9, 2005 | 10:26 AM
Angus's Avatar
Keep us in the know with the car.
Old Jun 9, 2005 | 10:41 PM
Johnnyger's Avatar
And the winning answer is..... Thermostat! Some of you guys guessed it. They replaced the thermostat. I also have a small leak in the water-pump, but I need to hold off on fixing that for a short spell for financial reasons. Thanks for your help on this, glad I didn't let that other guy take out the radiator!
