Sponsored by: CARiD
The Bad Window Motor Curse
Old Jun 21, 2005 | 09:39 PM
casey02ws6's Avatar
The one I bought was from Advanced Auto parts - it is a different brand than Siemans but it has "Siemans" in the part description....wierd. It was a straight forward install - took less than an hour.
Old Jun 23, 2005 | 01:27 PM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by Nine Ball
I installed an AutoZone window motor tonight. Getting the old one out was a snap when using the instructions I found while searching this site.
I provided instructions in my post above.
GM really did a ****-poor job on the design of these motors, and I guess they figured they would never need to be replaced judging by the way they decided to mount them without any access.
My new motor is about the same speed as stock, but now it will move the window all the way up or down without stopping. The odd part is that there is a slight angle-shift as the window goes up. Although the end of the track is a bit chewed, but the rollers never get that far. Its almost as if the roller rolls over something in the track. The track's path is clear and everything is greased up. The real issue is with the way the whole track and motor assembly is attached to the door. Its attached with rivits to the inner door frame and with use the rivits have elongated their holes. The whole bracket slides up or down about and 1/8" when the window is moved all the way up down or up. The door inner door frame also bulges slightly when this happens. Its just bad design all around.
Old Jun 23, 2005 | 01:51 PM
epic's Avatar
Well my motor is on it's way out. Sure enough, just when my warranty ends. Ended up going to Autozone and paid just a hair over $60 after tax for the Siemans replacement motor for my driver's side window. Glad to see it comes with that lifetime warranty.
Very thankful that someone was kind enough to layout these instructions:
http://shbox.com/page/windowmotor.html
Hopefully I'll get to it this weekend.
Finally found time to do this today, very straightforward. Only hard part is angling the new motor and as mentioned above, aligning those damn screws. Definitely glad I went this route!
