Sponsored by: CARiD
A/C only blows HOT air??
Old Jun 22, 2005 | 01:10 PM
WIKDWS6's Avatar
Default A/C only blows HOT air ???
My car only blows hot air with the A/C on. It worked last summer when I bought the car. Has anyone else had this problem? Thanks.
Old Jun 22, 2005 | 01:13 PM
cabesas's Avatar
My brother had the same problem it end up been a cloged line.
nasty99WS6's Avatar
ever consider the possibility that it might need to be recharged??
Old Jun 22, 2005 | 11:05 PM
Zymosis's Avatar
Word, check the easy stuff first my friend.
Old Jun 22, 2005 | 11:12 PM
Z28LS1camaroguy's Avatar
yeah, my last camaro ran out of a/c coolant or whatever its called, went to autozone got two cans and recharged the a/c and cold as ice.
Old Jun 23, 2005 | 05:03 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Do it yourself: Go to the parts store and buy a cheap gauge/recharge kit and 1 can of refrigerant. You can't screw it up because the gauge hose will only fit the low pressure side of the system (at the accumulator). If the pressure is low, add from the can until its in the normal range (around 24psi). -If there is a bad leak the pressure will drop off quick. -Fire up the car and turn on the AC and see if it works. If not, check and make sure the compressor is engaging. If not, could be several things (compressor, resistor, relay, fuse, pressure solenoid, etc).
Have it done by a professional: Drive to mechanic, do not pass go and bring some bucks with you. (I did this recently to the tune of $900 + for manifold hose, accumulator and compressor 'cause I didn't have time to deal w/it)
Luck.
Old Jun 23, 2005 | 05:58 PM
jaberwaki's Avatar
buy the $35 kit at your local auto parts store.... follow the directions....
and before you do that ... pop your hood, find your AC compresser.... make sure the belt did not pop off or break... if it did it would not have thrown a code of made a noise or anything... simply check that first... then do the kit...
Old Jun 24, 2005 | 07:22 AM
ttyson's Avatar
my AC was blowing warm too and it turned out the belt had come off and i didnt even know
Old Jun 25, 2005 | 03:19 AM
ls1 1990 VN's Avatar
If your car is now only blowing hot air, as has been said it needs regassing. Just an after thought, you haven't got a ricer trapped underneath somewhere have you.
Old Jun 25, 2005 | 03:52 PM
jaberwaki's Avatar
[tim alan confuzed] eeeeaaaahhhhhh???[/tim alan confuzed]
Old Jun 25, 2005 | 04:09 PM
99FormulaM6's Avatar
