Sponsored by: CARiD
front jack points?
Old Jul 26, 2005 | 12:40 PM
DrewSG's Avatar
Default front jack points?
I think this the right forum, but if not I'm sorry..
Where's the best place to jack up the front of the car for a simple oil change?
Old Jul 26, 2005 | 12:45 PM
conan's Avatar
Right behind the front tire under the z28/ss logo's you'll see the frame rails open up to a bigger pad, then it goes vertical up to fire wall.
Old Jul 26, 2005 | 04:10 PM
EugThinks's Avatar
There's a little rail-like tab at the front on each side, about 4 or 5 inches long with a couple of bolts... DO NOT USE THOSE UNDER ANY CIRCUMSTANCES. Using those tabs as jacking points will end up bending the fenders. I know the veterans consider that a no-brainer, but I'm a stupid newbie and managed to do that a couple of days ago... the driver's side says "do not jack" or something like that on it, but I looked at the passenger side first and it didn't say anything. Don't make my stupid mistake!
Sorry if you already knew that.
Old Jul 27, 2005 | 01:16 AM
MyKeE's Avatar
here you go...check this site out
Install University
you'll see the lift points here...along with some other useful information
Old Jul 27, 2005 | 09:34 AM
3pnt4maro's Avatar
or just get ramps and not worry about the body getting messed up..thats what i do
Old Jul 27, 2005 | 10:50 AM
Carter Hays's Avatar
The damn dealer lifted my car like that I didn't notice the fenders looking all f**ked up until I got home...Bastards
Old Jul 27, 2005 | 01:40 PM
3pnt4maro's Avatar
If they messed up the car there would be someone getting an as$ chewing and getting my fenders fixed..
Old Jul 29, 2005 | 12:11 PM
blackfang's Avatar
Yup. Took the Z/28 in to the shop to tac weld some tips for me being I didn't have a welder. I asked the guy if he has worked on F-Body's and Mustangs before and he was familiar with them. Ok good, I'll take his word for it. I go get me a soda, come back and see the lower fenders sticking out!!! WTF, I know they did not do what I think they did. yup. Those fvckers at meineke put the lift blocks on the rails in the front of the car under the fender.
Luckily at the dealership I have access to all i need and dont have to drive the car from one shop to another to get something done.
Old Aug 1, 2005 | 08:31 AM
DrewSG's Avatar
I bought the rhino ramps, and I can't get the car up on them.
It keeps sliding forward, I even put two cinder blocks in front the ramps, and it still kept sliding forward. Anyone know what I could do?
Old Aug 1, 2005 | 10:36 AM
Low N Slow's Avatar
I had the same problem, I tied a length of rope on the back of the ramps and and put it under the back tires, it holds the ramps as you are driving up.
Old Aug 1, 2005 | 11:20 AM
Brandon Boomhauer's Avatar
genious!
i use some 2/12s that I cut with an angle and stacked a few high..
cheaper than ramps, wider for the tires, and i made them....
Old Aug 1, 2005 | 02:22 PM
mrhzk35404's Avatar
That Is A Smart Idea With The Rope
