Sponsored by: CARiD
how to remove rivets from window motor?
Old Aug 6, 2005 | 02:15 PM
mostafa3k's Avatar
Default how to remove rivets from window motor?
what tool(s) do i need to remove the rivets when replacing my power window motor, i'm assuming a standard drill bit wont do the job.
Old Aug 6, 2005 | 02:57 PM
zeeya's Avatar
Take a small punch and hammer and knock the center out. Then drill them out.
Old Aug 6, 2005 | 02:58 PM
Danny2tek's Avatar
I used a regular drill bit.
Old Aug 6, 2005 | 05:39 PM
aaron653's Avatar
just got finished replacing mine today, used a regular drill bit. When you're putting it back in make sure you put it back in the correct order....I hope I never have to replace one again.
Old Aug 6, 2005 | 06:02 PM
mostafa3k's Avatar
Doesn't make any sense, a regular drill bit would just break it off, no?
Old Aug 6, 2005 | 06:21 PM
Dmoney's Avatar
Drill bit to break the rivets, then replaced with 32x3/8 small nuts and bolts.
Old Aug 6, 2005 | 08:31 PM
mostafa3k's Avatar
So just drilling 'em head on will break 'em?
Just want to know what's involved before i bust open the door panel.
Old Aug 6, 2005 | 10:21 PM
RoadHazard's Avatar
What he said. You will have to destroy the rivets and replace them with nuts and bolts.
Old Aug 7, 2005 | 02:16 AM
HFLDtA's Avatar
rivets are usually alluminum. a drill bit should work fine.
Old Aug 8, 2005 | 04:53 AM
2MuchRiceMakesMeSick's Avatar
A drill bit
Old Aug 14, 2005 | 11:05 AM
krzykrl96's Avatar
what size rivets would you use if you wanted to use rivets instead?
thanks
karl
Old Aug 14, 2005 | 11:55 AM
99blancoSS's Avatar
Metal Drill bit for rivets. Make sure your using a bit made for metal and not wood and you should be fine. Did a ball joint a few weeks ago, no troubles
Old Aug 22, 2005 | 09:44 PM
tx95camarogirl's Avatar
Go to NAPA and they can get you a box of 25 for what Chevy charges for 4. Theyy are 1/4" rivets so a regular gun will not put them in. I ordered one off ebay for $10 and used rivets instead of bolts. I did my PS about a year ago and the bolts, nuts with lock washers are loose. I will replace the nuts with rivets next weekend.
Old Aug 23, 2005 | 01:42 AM
krzykrl96's Avatar
i know they are a 1/2 inch but what length pull do you need?
thanks
karl
Old Aug 23, 2005 | 04:38 AM
Inspector12's Avatar
TT-TECH Veteran
Just use a 1/4" drill bit and drill through the fiberglass right on top of the rivet and it will come off easy takes about 20 minutes a side. THe new motor should come with nuts and bolts I use loctite and the lock washers both as they have a tendency to back off and become loose. You will end up with three small holes 1/4' but saves a bunch of time and headache, and no harm done. Good luck!
Old Aug 24, 2005 | 01:04 AM
cmn130's Avatar
drill bit
