Cracked plastic around mirror adjuster....
From: Live Oak, FL - in the woods where the creatures lurk.
Drivers' side manual mirror adjustment, the plastic corner piece literally split into 3 pieces shortly after I read the post about the interior door cracks. Managed to superglue it back together for now. Anyone ever seen this? This thing only gets touched when I Armor all it. Weird. 'Course I do have a black car.....
There may be other people who've had that problem, but fwiw I don't recall hearing about it before.
You'd have the D35 RPO for your manual-controlled mirrors; I'm guessing you don't have AU3 (power locks) or A31 (power windows), since your sig says 'no options'.
In that case, the part number for your 00-02 Camaro Accessory Switch Opening Cover is
10411468 for RH
10411469 for LH
It only lists for around $14, so if you get tired of looking at it being cracked, it wouldn't be very expensive to replace.
Would suggest using a better-quality product instead of Armor-All, BTW
10411468 for RH
10411469 for LH
