View Poll Results: change out your own spark plugs or take them somwher to get changed?
Voters: 831. You may not vote on this poll
Change your own spark plugs or take it to get serviced??
its easy as pie. done it once before and id do it again
ALL plugs will be removed from the top, remove drivers side coil pack and the tube going into the exhaust manifold and its super easy...
on another note, i belive my 140,000 mile car has factory denso irridum plugs in it with factory wires. i know my 105k mile car had factory plugs still....the missing out might be something else...
Originally Posted by 1993CaMaRoZ28ofIdAhO
im gettin new plugs and wires, my mechanic say $150 to do it. i really really want to do it myself, but i dont know how to do anything on my car. i think i would really mess **** up. argg NE help would be GREAT
I can do them in less than 30 minutes. Here is what I do. First, the tools needed: 3/8" ratchet, 1/4" ratchet, 3" extension, 5/8" spark plug socket, 10mm gear wrench (prolly could get by without but this is the stuff I use), 10mm socket, 10mm deep socket.
First, I start out by checking the gap on all spark plugs. Then I start on the driver side and take off all of the plug wires. Then I start with the #7 plug and work my way up using the 3" extension when necassary. I take the new plugs and put anti-seize around the threads, then screw them in with the 3" extension and 5/8" socket. Once they are tight I connect the 3/8" ratchet and tighten them (not too tight, just to where it's good and tight). Now that's the easy side IMO. For the passenger side I take off all the wires I can. Usually I'll leave the #8 on. Then I take off the #6 and #8 coil pack ( I have a 98 so they are individually mounted) with a combination of the 10mm wrenches. Then it is now easier to get the #8 wire off. I face toward the passenger side tire and put my arm back there with my palm facing the engine. You will suprised how much easier this is when you are positioned like that if you do not already do that. Then I start with the #8 plug with the same position. Comes out like a piece of cake. I continue all the way up to the #2 and then put in the new plugs with anti-seize. After that's done just put everything back together like you took it off.
Note: I don't have an emissions equipment so you may need to remove some of that to gain access to certain plugs/wires.
my technique is similar to 777's.
The driver side is easy.... and for the passenger side I removed the AIR tubes, and coil pack rail... and it gives you all the room you need.
Then I took the plugs out by facing the passenger side of the car from the front, and palm torwards the firewall. sooo much easier to get some torque on those things and get them out.
Anti Seize is the key though..... it will make it oh so much easier the next time around
**** I tryed To check my plugs today and couldn't even get off the boot but I did want mess anything up so i just left them alone since i have to drive the car to work. I will check them and change them if needed on sunday since I don't have to work till wednesday. This should be easy since i have installed headers on a few ls1's allready.
RIGHT. . .
Not to scare you off, but this job can be a pita if all your plugs are seized in the holes. The first time is difficult, it took me 4 hours. I'm sure I could do it in an hour now that I know exactly what I'm doing.
Easy as pie=changing plugs on a 4 banger Honda.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#33
Originally Posted by ss427ci
Your asking on a LS1tech forum.
I love the percentage difference. lol
When you pull your own plugs you can also compare them to a good Plug diagnostic chart and find A/F ratio problems or valve problems, etc.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Please do it yourself and save the heartache, and you will know that it was dont right!
#34
City Garage wanted to do mine for about 700.00, screw that I just just took off the whole coil pac assm off pass side and it was a breeze. Do it your self and save the money for upgrades
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#36
take your time the 1st time. Once you do it a few times its no big deal. i could do my 98's plugs in under an hour. I went to change my 2002s for the 1st time yesterday and snapped 4 damn plug wires one after another. Yeah i was pissed. Even after snapping 4 wires, and installing the new plus, wild goose hunting for replacement pre-cut wires, I was still done in 2.5 hours.
#40
Originally Posted by ChaoSS
Hello,
Lost manual. What is Plug gap 99 Camaro ss with LS-1,
Travis
Travis
