View Poll Results: change out your own spark plugs or take them somwher to get changed?
Change them out your self
86.04%
Take them to a mechanic
13.96%
Voters: 831. You may not vote on this poll
Change your own spark plugs or take it to get serviced??
Old 05-08-2006, 04:07 PM
  #121
SIC LSX's Avatar
i can do my with the pacesetter LT in about 10 mins 15min tops if you get a 3/8 it swivel and rap electrical tape around a bit it helps out a lot
Old 05-13-2006, 11:05 AM
  #122
j99fbody's Avatar
i always do change my plugs myself, not that hard and would not pay someone else to do
Old 05-15-2006, 07:10 PM
  #123
blackbirdls1's Avatar
just changed the drivers side this evening in a few hours, they were a bitch to get off wires and plugs, seized in and whatnot, but I got the hang of it and some tricks, going to do the passenger side tomorrow or day after (harder side)
Old 05-15-2006, 08:19 PM
  #124
billyb's Avatar
Originally Posted by gwj
Get #8 from underneath, really easy. Also disconnect the AIR rubber tube from the check valve and you can gently move the tube from the check valve to the manifold toward the front of the car to get #6 easier. A short 3/8" ratchet and a variety of extensions helps, including a short "wobble" extension. A universal can be helpful for breaking plugs loose, but I never install with it. Like was said, use anti sieze on the plug threads and dielectric grease in the boots (not on the electrodes).
DIS-CONNECT THE BATTERY!!!!!!!!! STARTER IS C L O S E !!!!!!!!
Old 05-15-2006, 08:47 PM
  #125
theantirotor's Avatar
i am lucky... i can see and change all 8 spark plugs right from the top with ease
Old 05-16-2006, 03:40 PM
  #126
god damnit, i'm having problemse with the passenger side, and the coil pack rail doesn't want to seem to come off or move upwards
Old 05-21-2006, 04:28 AM
  #127
MYTFASTSS's Avatar
How in the hell do you get #8 from the Bottom??? On my car (98 SS) the stock K. Member frame is in the way. On my old 89 Formula 350, I was able to get most of them from the Bottom.
Old 05-21-2006, 01:41 PM
  #128
losiguy's Avatar
I took off all the EGR ****, its like 4 bolts total and it frees up ALOT of room.
After I took EGR off I could reach every wire by hand, the last one on the passenger side I had to reach back and pull the bot off, then loosen it and change it from underneath the car. Im only 16 and my hands arent that big and it was tight for me but working with it for a few minutes I got it. Did all 8 of them in about 2 hours, first time ever changing plugs. Drivers side I got all 4 from the top, passenger side I got the first 3 from the top and the last one how I described above. DEFINITLY not worth paying someone for.
Old 05-21-2006, 01:59 PM
  #129
I will try from underneath when its not so hot outside itslike 100 degrees out right now, and I did remove the egr stuff for the passenger, helped a lot on 3 of them
Old 05-22-2006, 04:47 PM
  #130
losiguy's Avatar
Yea EGR makes it real easy. For the last one from the top pull the wire off the coil pack, then off the plug. It took me about 3-5minutes of pulling with my fingers back in there as hard as I could but the little bastard will come free eventually. Definitly helps if you take it off the coil first before pulling on the wire on the plug. Then jack the car up and there is a opening just big enough to squeeze your hand through, work your socket up in there and get it on the plug, then I used a like..1 1/2" extension and a socket and I got it. That one plug probably took 20 mins all togethor.
-Chad
Old 05-22-2006, 05:02 PM
  #131
Mike02Z's Avatar
Anyone know if those shorty sockets and GM 5 degree open end racheting wrench are worth the 30 bucks an ebay seller is charging? I have 25k on mine and would like to change my plugs but have no way of getting the number 8 plug from underneath. I don't mind spending 30 bucks if it helps.
Here is a link
http://cgi.ebay.com/ebaymotors/TRANS...spagenameZWDVW
Old 05-22-2006, 05:56 PM
  #132
Rebob5's Avatar
I have the slp version of that socket and when I changed the plugs on my LT1 last month I never used it. I just used a regular length one with a ratchet and it worked fine.
Old 05-23-2006, 06:19 AM
  #133
losiguy's Avatar
Here is a link
If you really really try you should be able to get #8 from up top but it will take a while of working your way and fidgeting with a socket, itd be a very tedious process but I think it could be done. If not you could check your local auto parts store and see if they have drive on ramps which work great. ( As long as your not lowered alot)
If you take the coil pack brackets off you can get to #8 from up top easier. Just take off all the EGR and the coil pack brackets and go at it.
Old 05-23-2006, 07:09 PM
  #134
joecar's Avatar
#8 is accessible from underneath if you reach up at the rear of exhaust manifold/header, from where trans. mates to engine (i.e. rearward of engine cross-member).
Old 05-24-2006, 06:34 PM
  #135
Mike02Z's Avatar
After reading as much as I could on this I went out and got this at Home Depot. Seems like this may be the ticket to get #6 and #8 from the top. 14.99. I'll let you guys know how it works when I tackle this job next weekend.
Old 05-24-2006, 08:50 PM
  #136
ZoFastSS's Avatar
Wink
The only way to learn is do it yourself, I've done mine five times, and will be working on the sixth time over the weekend.
Old 05-28-2006, 04:31 PM
  #137
well i finally got 8 out, went at it today with my friend, took about 2 hours lol sad I know, but removing the coil pack rail makes it possible, don't even bother putting in that back bolt back in, so next time it will be easier to remove and whatnot
Old 05-28-2006, 11:42 PM
  #138
ss1129's Avatar
Its hella easy after the first time. You grow extra joints and **** to reach them.
Old 05-31-2006, 09:52 AM
  #139
joecar's Avatar
I just put headers on an F-body, and all plugs are easier to access, and #8 is very easy from below
(no need to remove anything other than AIR tubes from manifolds/headers).
Old 06-10-2006, 06:29 PM
  #140
Mike02Z's Avatar
Originally Posted by 4150
I bought that and ended up not even using it, I'm able to get at everything with just a normal sparkplug socket and assorted length extensions from up top after removing the coil packs and the air crap.
The ebay item is a pretty good deal though IMO, too bad I didn't use it.
Yea, I bought it along with indexing ratchet but didn't wind up using any of them. In the end a 3/8" Flex head ratchet is what I used to get to all 8 plugs from the top side. I used a universal and a 3" extension as well. The only thing the indexing ratchet helped me with was the coils pack bolts. I like tools though so I'm not complaining.
Quick Reply: Change your own spark plugs or take it to get serviced??
