Sponsored by: CARiD
injector cleaner
Old Oct 1, 2005 | 07:32 PM
WS6nJAX's Avatar
Restricted User
Default injector cleaner
looking to use a injector cleaner to maybe help with my ping problem. can i get some opinions as to what some of you prefer??
Old Oct 1, 2005 | 07:37 PM
mustgofasster's Avatar
From what I understand the only way to properly clean the injectors while they are on the car is to go to the dealer for a fuel syestem cleaning. Its only like $150 and works good. The stuff you pour into the gas tank causes more carbon build up. IMO
Old Oct 1, 2005 | 07:52 PM
Silver02TA's Avatar
I believe Super Lube does the same thing for ~100, and they always give you something off of that if you ask for a deal. I got mine done for 75 when I had my old Camaro and gas mileage when up drastically during the next tank of gas.
Old Oct 1, 2005 | 07:55 PM
SSRZ28's Avatar
ive used Seafoam at my work and it seems to work really well. i would be carefull about those injection cleaning services from some shops. we offer that service and it isn't anything worth $150. pepboys offers an upperend cleaning thing that really isn't anything either.
Old Oct 1, 2005 | 10:48 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I use Redline fuel system cleaner. Works great. Always given me an improvement in MPG and eliminated any KR/pinging issues I've had.
Old Oct 1, 2005 | 10:54 PM
Raise's Avatar
what exactly do these shops do to clean your fuel system?? im guessing it does a hell of a lot better job than the **** u pour in your gas tank, right?
Old Oct 1, 2005 | 11:04 PM
SSRZ28's Avatar
some just attach a tube to your intake and run a cleaner through it while the engine is running. ive seen them do this and when the car is revved black smoke would come out the tail pipe (carbon buildup). they would do this till there was no more smoke.
Old Oct 1, 2005 | 11:30 PM
SSDude's Avatar
You should try Fuel Power 60. It works!!! If you use this stuff there is no need to go to the dealer and get ripped off.
Old Oct 2, 2005 | 09:46 AM
Raise's Avatar
how does fuel power 60 work?? could i do it myself??
Old Oct 2, 2005 | 02:13 PM
Osiris's Avatar
I'm with SSRZ28! Use Seafoam! you can get it from OReilly's, doesn't cost much and you can also use it as a full engine cleaning agent. Just pour it into the crank right before a oil change and it will get all the gunk out of the engine also. Great stuff! Just don't leave it in you engine long. Pour it in, run it for like 10 min. then drain the oil an put in some Mobile 1!!!!
You can use it on your gas lawnmore to keep it running like your car! Just perfect!
Old Oct 2, 2005 | 03:02 PM
LS1_Unleashed's Avatar
Anyone else know how much pepboys charges for a good cleaning?? What do these shops do when they clean the engine out?? Does it help and for how long??
Old Oct 2, 2005 | 10:48 PM
SSDude's Avatar
http://lubecontrol.com/
Old Oct 3, 2005 | 07:00 PM
Patman's Avatar
Fuel Power is also what I use. I put some in with every tankful (1oz for every 5 gallons)
