Sponsored by: CARiD
Color of your oil?
Old Oct 11, 2005 | 07:19 PM
FelixIlka's Avatar
Default Color of your oil?
? For some of you, when you change the oil in your car, does it come out "nearly" as clear as when you put it in? If so, how many miles are you going before changing it?
I ask because I changed mine and it was black, like all the other times I've changed it on my TA, my wifes Sunfire and on my intrepid. I've heard people get it to come out nearly the way it went in but am I missing something?
Old Oct 11, 2005 | 07:25 PM
2K2WS6TA's Avatar
Mine always comes out looking black, dunno how people get it to come out looking like when they put it in
Old Oct 11, 2005 | 08:04 PM
BLUE99T/A's Avatar
Maybe they change it every 500 miles. Mines always dark but never black because I have to add so much between changes.
Old Oct 11, 2005 | 08:54 PM
Zymosis's Avatar
Dark Greenish....Then again I'm a sucker for that German Castrol (Sucker isnt always bad in this case)
Old Oct 11, 2005 | 09:21 PM
longdaddy's Avatar
if you're concerned about how your oil comes out, there are companies that can do analysis on your used oil to tell you exactly what it picks up.
Old Oct 11, 2005 | 10:08 PM
FelixIlka's Avatar
How much does it cost?
I've heard if you change the oil a few times at 1500 miles ( or until it's not black ) then you can start running it 3k+ miles without it becoming black.
Old Oct 11, 2005 | 10:31 PM
longdaddy's Avatar
http://www.blackstone-labs.com/standard_analysis.html
$20 here
Old Oct 12, 2005 | 09:04 AM
paper doll's Avatar
mine will come out black if i change it every 2 months , or 2k miles, which reminds me......
Old Oct 12, 2005 | 09:15 AM
BlueSix's Avatar
I love the people that spend the extra money on fully synthetic oil, but don't use it as long as they can. Every 2K miles? come on, every fully synthetic oil made today can go well past 5K miles.
Old Oct 12, 2005 | 11:24 AM
taintedmeat's Avatar
I run my German Syntec 7k miles.
Old Oct 12, 2005 | 02:04 PM
BlueSix's Avatar
Then you're smarter than the average bear!
Old Oct 12, 2005 | 02:13 PM
Chas1's Avatar
I change mine every 6 months, I don't even get to 3k in that amount of time. And it's very clean when I change it.
Old Oct 12, 2005 | 06:30 PM
Patman's Avatar
On my last interval I went 8000 miles and the oil came out darker than new, but nowhere near being completely black. Analysis showed there was no fuel in it, very little dirt, and not all that much in the way of wear metals, so this is the reason why the oil came out still clean. I plan on doing longer intervals in the future. (eventually my plan is to change the oil only twice per year, or roughly every 10,000 miles)
Old Oct 12, 2005 | 06:54 PM
FBDYLVR's Avatar
What filter do you run that keeps it so clean?
Old Oct 13, 2005 | 12:40 AM
FelixIlka's Avatar
Mine was changed at 3k miles... maybe I SHOULD do an oil analysis...
Old Oct 13, 2005 | 12:41 AM
FelixIlka's Avatar
Oh and how would one go about "fixing" things to make it not so dark?
Old Oct 13, 2005 | 05:04 AM
stevemilz's Avatar
You might have to change the oil, fire it up, drain the oil, and then put some new oil in it. Have you thought about a oil cooler? I have a Earls Temp-A-Cure, www.holley.com and click on Earls. If you do get one get a thermostat, or it will take like 20min for the oil to hit 160-170 degrees
Old Oct 13, 2005 | 09:56 AM
LS1-450's Avatar
Change my German Castrol every 5K or twice a year regardless of mileage. Twice per year should be a minimum as it's the only way to remove moisture unless you have a bypass filter set-up.
Can't say I blame those whom change every 2K while using synthetic. It's better to error on the side of caution & it's never a bad thing, just costs more.
Old Oct 13, 2005 | 10:16 AM
Zymosis's Avatar
I'm at 4500 on my interval right now.
Old Oct 13, 2005 | 10:27 AM
Fogle07's Avatar
i use german castrol in my truck and change it every 4k and it comes out pretty black
