Sponsored by: CARiD
pcv hose question
Old Oct 20, 2005 | 06:09 PM
2002CobraKiller's Avatar
Default pcv hose question
on the pcv hose the part that connects to the manifold is there supposed to be a little hole in it to let it breathe? i have a little hole in mine right before it connects to the manifold and i can hear it sucking air pretty loud. i really need some help with this one guys let me know asap. thanks
-Mike
Old Oct 20, 2005 | 07:29 PM
jimmyblue's Avatar
Moderator
The breathing should be done (on an Fbody?) through
the hose to the TB and the suction through the port
on the intake manifold. No outside air should be taken
in that doesn't come through the MAF first. Holes in
the hoses are not right.
Old Oct 20, 2005 | 07:33 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yes, a hole in a PCV line is not supposed to be there. That hole is a vacuum leak.
Old Oct 20, 2005 | 07:41 PM
when i cover up the hole it wants to turn off and i let it go to breathe and it idles fine what is wrong?
Old Oct 20, 2005 | 11:45 PM
jimmyblue's Avatar
Moderator
It learned to live with it (fuel trims) and now it's
bent in the head. Plug the hole and let it learn
back right.
Old Oct 21, 2005 | 10:02 AM
thanks jimmyblue, do you know where to buy one of these hoses its the seperate piece of the hose that connects to the manifold the rest of the pcv hose that runs along the sid of the manifold is fine.
Old Oct 21, 2005 | 12:10 PM
~JOSHUA's Avatar
If you plug the hole with your finger, it'll act like it will die, but it won't. Worst case, start the car again and crack the throttle open while you plug the hole. Get a new hose/pcv and disconnect the negative terminal on the battery, it'll make the computer do the idle relearn- kind of like when you swap cams.
Old Oct 21, 2005 | 11:56 PM
do you know where i can get a new hose?
Old Oct 22, 2005 | 01:19 PM
BLOODTA's Avatar
After I got my LTs , I went to CAM to get a tune and dyno. It was only making 302 rwhp, we couldn't figure it out, one of the guys found it. It was a hole (a huge hole) in the pcv valve. They did the duct tape mod and, then dynoed again it made 320rwhp. That little hole made a big difference.
