Sponsored by: CARiD
what is "loading up" the engine
Old Nov 8, 2005 | 05:34 PM
WANARUNM's Avatar
Default what is "loading up" the engine
wasnt sure where to ask this but but when someone says the motors loading up what does that mean? I know its somethin you dont want
Old Nov 8, 2005 | 11:39 PM
DramaFoYoMama's Avatar
Dumping gas that doesn't get burned. This should only happen to a carbureted motor.
Old Nov 9, 2005 | 06:07 AM
WANARUNM's Avatar
so these camaros (f-body) shouldnt or couldnt load up?
Old Nov 9, 2005 | 07:24 AM
The PCM can only compensate so much for a rich condition. If your car is running that badly, you'll know it because it will throw codes and run like ***. It should just run rich and not "load up."
Old Nov 9, 2005 | 05:50 PM
WANARUNM's Avatar
Well that makes sense, I just had a cam swap and bore. A little backfiring now and then when i rev it up, a little gas smell after i shut it off, but no codes yet.
