clogged catalytic convertor?
Thanks
Thanks
If your cat was broken inside, it would rattle when idling and when you bang on the cat. As far as it being clogged...? I would take the pipe off by the 3 bolts at the top and the 2 at the y-pipe. After you take it off, beat the **** of the honeycomb material inside. Gut those bastards!!!
Your car will run better with the slighly less backpressure anyways. Thanks
It is likely that after 51,000 miles you will have a hell of a time getting the three manifold-to-cat bolts out without breaking one (or more) of them.
Thanks
