Interior Air Blower Stuck In One Position
Has anyone ever had the air blower stuck in one position? It seems to be stuck in the "blow air on feet" setting. As far as I can tell, the a/c still works, it's just that it will only blow to your feet.
Thanks in advance!
Yeah - the metal shaft still turns. Right now there are three options: off, a/c on (blows to your feet) and blower only (blows to your feet). The temp control **** still works fine and the blower speed adjustment **** still works fine, but you can't switch the location that the air blows to.
Would I start by checking under the hood or checking behind the dash for vaccuum leaks?
Hmm . . . I had the valvesprings replaced last Friday, and this happened Friday night at the track . . . Maybe I'll call the shop. I didn't see how the repair could be related to the problem, but that may be it!
Thanks!
