How bad is this?
BTW.. I've got 146k miles on my car... I probably should replace...
What do you think?
At what point in time should I replace the ball joints?
Another question that I have is the back end has been vibrating a lot as well. last night I read on a couple of boards that people have replaced their U-Joints, how valid is that? The vibration is felt in the "seat of your pants" and seems to go away once you turn the steering wheel slightly to one side or the other. GRRR... looks like it is maintenance time !
As for the ball joints, they only need to be replaced if they have play in them. What you will need to do to check this is lift the car up in the front by the lower control arm. Then with the wheel on, try to wiggle it up and down. If you feel a clunk, then you likely need to replace the ball joints. To check, you can have someone else wiggle it while you look at the spindle in relation to the control arm for movement.
As far as your vibration goes. If it goes away when you steer, I would tend to think that it is coming from the front of the car. Check all your tie rods.
While the car is on the ground, try to wiggle the wheel from side to side. If you feel a clunk like this, it is most likely a INNER tie rod.
Then lift the car in the air and wiggle the wheel from side to side. If you get a clunk here, it is most likely an OUTER tie rod.
Also you can check for wheel bearing play in a similar manner. Just make sure to look and see what is moving in relation to what. Hope this helps
I will perform that ball joint test (that sounds kind of personal doesn't it?)
Most likely I am ordering a sway bar today, it needs replaced because it is cracked where the bolt is.
