Sponsored by: CARiD
Driveshaft u-joint
Old Jan 4, 2006 | 07:22 PM
Shutout's Avatar
Default Driveshaft u-joint
How can you tell if the driveshaft u-joint is going bad? Is their a way to check it or test it? I have been getting a rattling sound from the rear of my car and after the usual checks for loose bolts,exhaust etc, I figure I would check the u-joint. Thanks.
Old Jan 4, 2006 | 08:48 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
jack the car up and try to turn the drive shaft by hand and look and both u joints you'll be able to tell for sure if it is the joint.
Old Jan 5, 2006 | 04:19 PM
2002_Z28_Six_Speed's Avatar
If it is a U joint it should squeak when you are going slow and vibrate down the highway. How many miles are on your driveshaft?
I don't think the U-joint would rattle.
Old Jan 5, 2006 | 05:34 PM
Shutout's Avatar
My car has 36k on it. The car only makes the noise when I am coasting, not in gear, and turn left and right. When the car is in gear I does not seem to make the rattle. The rattle speeds up and slows down with the speed of the car.Almost like when you put a baseball card in the spokes of a bicycle tire.
Old Jan 5, 2006 | 07:20 PM
Well you could have a driveshaft shop inspect it. Maybe they could do it for free? Ask them.
Old Jan 5, 2006 | 07:37 PM
CW00BlackTA's Avatar
Get under the car (jack stands), grab the drive shaft by the joints and carefully move it up and down, side to side etc. Start with the rear as it usually goes bad first. There should be no play in the joints. If you are getting a high frequency vibration it should increase with speed. Sometimes you can't feel a bad joint but you can tell from experience it's going out. If in doubt, replace the rear joint and see if it makes a difference. Pretty cheap if you do it yourself.
Get under the car (jack stands), grab the drive shaft by the joints and carefully move it up and down, side to side etc. Start with the rear as it usually goes bad first. There should be no play in the joints. If you are getting a high frequency vibration it should increase with speed if it's a bad u-joint.
Old Jan 6, 2006 | 05:15 PM
Shutout's Avatar
My car does develop a vibration at 50 to 55 mph only in 4th gear. When I am in 5th or 3rd their is no vibration. When in 4th and go faster than 55 the vibration goes away. Go figure.I have never checked the u-joint, but I did try turning the driveshaft. Their was about one eighth of an inch of play in it.
