Sponsored by: CARiD
Electric problem QUESTION?
Old Jan 10, 2006 | 07:23 PM
berwicknitro's Avatar
Default Electric problem QUESTION?
I was wondering if someone could tell me why my lights pulse. I replaced the belts and tensioner, but it's still doing it. I had the alternator checked, and it's charging fine.
Do you think the internal voltage regulater is starting to go.
Any help would be apppreciated. Thanks
Old Jan 10, 2006 | 09:52 PM
2K2WS6TA's Avatar
Does they pulse alot, or just once in awhile ? If it's just once in awhile, it's the AIR pump cycling, and can be considered normal
Old Jan 12, 2006 | 06:49 PM
Hi, It pulses all the time, It seems to pulse faster, with RPM.
I did a search, and it seems that alot of people are having the same problem.
Can someone tell me the odds, if I change the alternater it fixes the problem.
Or is it something some of us have to live with.
Thanks, Brad
Old Jan 12, 2006 | 09:04 PM
Trev_SS's Avatar
i dont know but my dads camaro and his van
Old Jan 13, 2006 | 02:08 AM
STA's Avatar
STA
Recently my trans am had the same pulsing lights problem. When on the freeway at night the check gage light would pulse along with the headlights. I did some research and someone posted on this site that its caused by the voltage regulator going bad in our alternators. So I swapped in a new 160 amp alternator and problem solved. Although, it still pulses a small amount once in a great while, but not as bad or frequently as before. In other words you won't notice it unless your looking for it. Its a common issue with our cars.
Old Jan 25, 2006 | 11:48 PM
bulletLS1's Avatar
i've also read that it could be a dead cell or a cell going bad in the bat.... (wow!)
Old Feb 2, 2006 | 10:34 PM
BorgX's Avatar
I have this problem now. I am on my second alternator already... took it about 3 months to get the second one. This sucks! I have a new battery and this did not correct it. Any other ideas from anyone? Thanks in advance!
Old Feb 7, 2006 | 12:47 PM
bulletLS1's Avatar
RECHECK THE ALt GROUNGING!
it is true that the alt is solidly bolted to the engine but the ground straps sometime get loose, also I`ve KAPUT three alts because the hyd pump leaked directly to the alt, and my car was definetelly assembled on monday because the DUM F#CK who did had a hangover!, the signal wire to the alt was TOO SHORT, so it kep tightening ritmically w/eng movement, Thus light flicker!
