Sponsored by: CARiD
99 WS6 Low Coolant Light?
Old Jan 11, 2006 | 08:25 PM
Rocktagon's Avatar
Default 99 WS6 Low Coolant Light???
I've got a 1999 TA WS6 with 60K on it. Recently the little red low coolant light has come on. It used to shut off once the car warmed up but now is on constant and yes, I've checked the levels. Everything is right where it's supposed to be and the engine stays in the normal operating temp. So, as far as I can tell nothing is wrong. Could it just be the sensor or what? Just wondering if anyone else has had this problem and if so, how it can be fixed?
Old Jan 11, 2006 | 08:57 PM
Pokeyhawk's Avatar
I've got the same problem on my 95 Firehawk. I believe it is a common problem. The sensor just goes bad and gives the false indication. I wouldn't worry about it, just change the sensor when you get a chance.
Old Jan 12, 2006 | 11:29 AM
2001NBMZ28's Avatar
You can try removing and cleaning the sensor, replace it with a new one, or just unplug the sensor and the light will stay off. Believe 2K and up F-bodies don't even have them, mine doesn't.
Old Jan 13, 2006 | 12:53 AM
98boxer's Avatar
You have low miles but pay attention to the water pump gasket maybe water pump gasket is leak coolant slowly. If not as mentioned alread replace the sensor its on the passenger side. Sensor sticks out of the radiator its just below the top of the radiator.
Old Jan 14, 2006 | 05:27 PM
Rocktagon's Avatar
I'm having trouble locating the sensor. Is there something that stands out that I could look for or what?
Old Jan 15, 2006 | 10:35 AM
2001NBMZ28's Avatar
Look at the back side of the radiator, about 4-5" below the radiator cap.
Old Jan 15, 2006 | 10:36 AM
tomss99's Avatar
yup mine use to do the same thing... i took the bitch out since im always checking my motor out anyway
Old Jan 15, 2006 | 11:07 AM
02WS6Bird's Avatar
got a pic?
