Sponsored by: CARiD
Blue Smoke
Old Jan 16, 2006 | 12:01 AM
just1news6's Avatar
Default HELP!!! is this NORMAL BLUE SMOKE
have a 2000 ls1 trans am ws6 and it blows blue smoke every now and then if i open it wide open. it doesnt do it all the time the car has no cats and an x pipe and 1 chamber turn downs and it seems to do it the worst when it is cold. There seems to be no power loss and it just burns some oil just wanted some feed back!!!! PLEASE help im concerned by the way the car has no egr valve smoke happens at high rpm
Old Jan 16, 2006 | 12:15 AM
Joel_SS's Avatar
More than likely your piston rings are toast.. Start saving for a new motor.. Do not feel bad I am in the same boat...
Old Jan 16, 2006 | 12:18 AM
'Trust''s Avatar
How much smoke? Like a train, or just a puff at WOT? If its a puff dont worry about it, more than likley its carbon build up. If its like a train, its your rings.
Old Jan 16, 2006 | 08:52 AM
BURN'EM's Avatar
The cats have alot to do with it. With just a light puff from a wot or at start up normaly the cats would catch that. it being carbon, or blow by sucked through the intake at wot.
Anytime the cats are out thats what you have to deal with.
Old Jan 31, 2006 | 01:52 PM
just1news6's Avatar
thanks guys for all the help
Old Jan 31, 2006 | 05:46 PM
Sebring 00's Avatar
Blue smoke is oil. Could be several things. Do a cylinder leak down test to pinpoint the problem.
Old Jan 31, 2006 | 05:48 PM
Z2K_MrJ's Avatar
Board Certified Idiot
correct me if i am worng but you should look at that as a good thing means you dont Beat your car carbon build up. as stated above. when at my friends wook haning out i see lots of C5 Vettes do that all the time. Cause of the old folks dont ever get on them to CLEAN it out. its good every once in a while to beat on your CAR HEHE
Old Feb 1, 2006 | 11:20 AM
PheonixTA99's Avatar
stop with the wot and it will dissapear! (or uintil you have eough $$ for a new motor, then just tear it up)
Old Feb 1, 2006 | 01:16 PM
'Trust''s Avatar
I see alot of C5's do it too
Old Feb 23, 2006 | 11:32 PM
just1news6's Avatar
wouldnt it smoke at every wot run all the time if it were the rings im thinking it may be the pcv no smoke out of teh oil cap and it seems to fire fine with normal ls1 oil consumption 1 qt ever 1000-1500 miles
