good replacement for power window motor?
anyhow, power window motors, and good repalcements
i remeber reading here a specific part from autozone. can somone give me that part (or an even better motor replacement?)
however the lifetime warrenty does mean something if your gonna be changing it out every year, im sure you know its a very tedious job yeah?
thanks fort he reply, il have tog e one whent he warm weather picks up
hehe this winter is bad ...tires, rotors, power window motors, driver door panel, clutch all needing replacement..not bad one at a time, but when it all breaks at once...
take off door panel
pull plastic shealding off drill threw fiberglass door skin in 3 places where rivots are.
put new motor in with new bolts. put back together
and for your information auto zone will tell you the motors are different on each side but they are not so you have liftime on both sides after just buying one!!!!!!!!!!
take off door panel
and thanks for the rename of the thread.
but as fare as the replace ment motor I have done it and have multiple trans am's and it does work auto zone does not look at the used parts to make sure they are the exact brand they open box and see if a window motor is in it then close it back and give you your money
Am I missing something? I don't see how its is possible to do.
