Sponsored by: CARiD
Check Engine Light Came On
Old Jan 17, 2006 | 01:43 PM
afdude402's Avatar
Default Check Engine Light Came On
Hey guys i dont know were to put this but i really need your help
today i was driving my 1999 dodge ram 1500 in 4x4 since there was still snow out and the check engine light came on i got home fine and it runs like normal, i listened to the motor and it also sounds like it is running fine. i dont know why the light came up and wont go off please help me out
Old Jan 17, 2006 | 02:31 PM
afdude402's Avatar
anyone
Old Jan 17, 2006 | 02:38 PM
skywatcher's Avatar
The first thing I'd check is if the gas cap is screwed on all the way.
Old Jan 17, 2006 | 02:39 PM
afdude402's Avatar
already did that but thanks anyways
Old Jan 17, 2006 | 03:01 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Only way to see what the light is about is to hook up a scanner. Can you get to someone that has an OBD scanner?
Old Jan 17, 2006 | 04:27 PM
twort's Avatar
take it to autozone and get it scanned for free.
Old Jan 18, 2006 | 01:06 PM
perezpowerbuilders's Avatar
Disconnect the battery completely. This will clear the memory on your computer. If there really is a problem the check engine light will come back on. Then take it to autozone and get it scanned. Fix the problem.
Old Jan 19, 2006 | 12:45 PM
273sunsetZ's Avatar
My Catalytic Converters are bad, and it drives, and sounds normal. Although there is a distinct smell when I stop after WOT. My guess is that it could very likely be o2 sensors or something of the sort, especially if you have an after market exhaust. Do You?
